Results 1 to 7 of 7
Thread: Wire specs
    Nov 2016
    Wire specs
    I basically have know practical knowledge on wire types. Does anyone have any good reference material on wire used in the RF wiring harness? I have an older revision harness and need to add to what I have (for the hazard switch for example). I'm concerned I'll oversimplify what I need, but hopefully I'm overcomplicating it.
    Fairfax Station VA
    I use this chart http://www.allfordmustangs.com/forum...ingdiagram.jpg to determine what gauge wire to use. It's VERY conservative; other charts allow for smaller gauge wire or longer runs.
    Figure out how long a run you need & the current to be supported, and choose your wire gauge accordingly. For your hazards, you'll be fine with 16 gauge unless you're doing something exotic.
    If you want to know specifically what RF used, give them a call. Their tech support has always been very knowledgeable when I had a question.
    MK IV Roadster #8631
    Lost Wages, Nevada
    Pretty good idea to use GXL or SXL wire rated for automotive applications in whatever gauge you need to power your device.
    Buy your wire at automotive shops, NOT HD or Lowes, they don't [usually] carry anything but THHN THN or TW (house wire) not rated for 125°C.
    Doc
  4. Thanks phileas_fogg thanked for this post
    Senior Member CFranks's Avatar
    Mar 2018
    Berwyn, PA
    Wirebarn is a great source for GXL and TXL wire, they come in multi-color packs too:
    https://www.wirebarn.com/Automotive-...packs_c_1.html
    Santa Clarita, CA.
    X 2
    Great resource and quality wire
    Quote Originally Posted by CFranks View Post
    Bakersfield, CA
    GXL? TXL? SXL? Confused? Here’s a quick read....
    https://www.kayjayco.com/catPWireSelect.htm
    Kurt
    Build thread
    Mar 2013
    Fort Collins, Colorado
    I don't have any experience with a RF harness, but I do know that Painless uses TXL.
    I have also had good experience with Wire Barn. There are wire calculators on their web site.
    MK2 #3319.... On the road since 2002 with a lot of upgrades
