Results 1 to 4 of 4
Thread: Drivetrain offset
    Member aspbite's Avatar
    St. Petersburg, FL
    Drivetrain offset
    Anyone know what the side to side offset from the center of the frame is ?
    I know it is offset toward the passenger side.
    Also what is the pinion offset on the fox 8.8 rear end?
    Been searching and can't find this info.
    Mark IV, Boss 351c, Toploader, Levy 5 link
    Seasoned Citizen NAZ's Avatar
    Lateral offset is 9/16" for the 8.8 straight axle. For comparison the 9" has 15/16" offset.
    St. Petersburg, FL
    Thank you
    Good to know. Thanks
