Results 1 to 5 of 5
Thread: Header bolt difficulties
Hybrid View
    Dracut, MA
    Any words of wisdom?
    I have the FFR headers for the Coyote engine.
    Bottom bolts are tough to reach, can’t even get the two center bolts started.
    Any special tools or do I need to find someone with longer fingers😁
    Ray
    Senior Member Fixit's Avatar
    Aug 2017
    Minneapolis 'Burbs
    Here's a link to the "fun" it was on #9365... it's really not too bad!
    John D. - Minneapolis 'Burbs
    Dracut, MA
    Thanks John for pointing out the obvious. Reuse some of the existing studs.
    Ray
    Aug 2019
    Header bolt strategy
    Quote Originally Posted by Cobra Ray View Post
    Ray
    I have the Daytona coupe with Gen 3 Coyote. What worked for me on the header bolts is this:
    I had to remove them after engine install as the headers will not fit into place with the factory header studs in. Also, header bolt holes did not all align to allow for exact fit - soooo:
    I widened the bolt holes as needed in the headers using a drill and file. Install the header studs back in with header and gasket in place. If you have any trouble getting the header studs back in, then use flange head M10 x 1.25 x 30mm bolts. Use whatever tools you have that will fit. I used a variety of rachets, tight space wrenches and whatever could fit. As mentioned by another thread there is at least one that allows only the open end of the wrench with 1/8 turns at a time. Its a PITA job and caused a lot of bad language!! In the end I spent many more hours than I thought on this.....Just like on most other aspects of this project - good luck!!
    Nov 2019
    Charlotte, NC
    Quote Originally Posted by BigShooter View Post
    Ditto...best to mock up headers prior to engine install. Bolt holes on the flange don’t line up perfectly and need a little massaging. Ratchet wrenches were a lifesaver along with an array of extensions and universals.
