I have tried to research this and I can't figure it out. I believe that I have wired my switches correctly per the RF instructions. I used the 3 pole On-On switch from the kit for the high beam switch and as a result, when it is on "low" and I turn on the headlights, I get lows. When I switch to "high", I get high beams alone. I assume that it would be ideal to get low and high beams when I turn on the high beams. Is this correct? If so, do I need to work a relay into this circuit. I feel like I am missing something.
