Thread: Ignition Switch Issue?
    Feb 2018
    Hey guys, just about to fire up the engine for the first time, but running into an issue, or just confusion, with the ignition switch.
    Building a '33 Hot Rod, using the electrical harness that comes with the kit. When I connect the battery cable to the battery, and test the power coming to the ignition switch, I have current on 3 of the 4 terminals... red, orange and brown. Blue, as expected has no current on it since that (successfully) turns the starter when I turn it all the way to the right. But if the key is out, I still have power on all three (R/O/Br) wires. Turn the key to the right one click (aka Run), same thing. Turn it back to the Acc spot, same thing, power on all but Blue. I would expect there to be a difference (Orange off, Brown off) when the key is out or when it's turned back to Acc. Is this a faulty ignition switch, or an I misunderstanding what should be powered when the key it out?
    To be more specific, I'm using the Sniper EFI, and looking to power it with the Orange EFI/Coil wire from the harness, but that wire always has power, so the EFI is always on; even when the key it out. Which doesn't make sense.
    Thanks in advance for your insight.
    Rob
    Sounds like a defective switch. Check the continuity of the terminals at each switch position with no wires connected.
    Off = No continuity between any terminals.
    ACC = Continuity between battery and acc terminals.
    RUN = Continuity between battery, ign and acc terminals.
    START = Continuity between battery, ign and start terminals.
    Heart of Dixie, Alabama
    I could see this happening if you have the + on an accessory lug.
    Feb 2018
    Got it figured out. I am using a one-wire alternator, and sure enough the brown Accessory wire was connected where it shouldn't be, so I was getting power back through to the ignition. All is good now. Thanks for the advice!
