Results 1 to 8 of 8
Thread: How to Tow a MK1
    Dec 2012
    Houston, Texas
    How to Tow a MK1
    My MK 1 Roadster is not running and needs to be towed. Are the front bumperettes strong enough to pull the car on to a rollback trailer? If not, where can I hook it without damaging the body?
    Phil: FFR 3121, Frame #2050, Mk 1.5, built 2002, 1991 donor with Blueprint 302 long block and 1993 Cobra intake, BBK 70mm T/B, no smog, power steering, T-5 and 3.55 rear.
    mburger's Avatar
    Punta Gorda FL
    Attach to the front lower control arms. Don’t use the quick jacks. Tow driver should have ramps to get you onto the tow deck at a better angle. Also, with a T5 you have to use a flat bed otherwise you’ll damage the transmission.
    Mark
    Super Moderator
    R. Button's Avatar
    Elmira, NY
    The tow driver should put blocks of wood up between the cable and the frame to help keep the cable down, away from the body.
    Most of the rollback - flat bed drivers will extend the flat bed back to help reduce the angle. I was towed once after a blowout on my rear tire and the tow operator was very careful as well as knew what to watch for.
    Ralph Button
    FFR 1436 (PROUD Owner of an Original Mark I)
    400,013 miles as of 11/1/2009
    417,840 miles as of 8/12/2010
    435,021 miles as of 12/19/2011
    Now a well broken in 347 engine
    523,145 miles as of 7/29/2014
    601,165 miles as of 6/1/2018
    615,215 miles as of 4/23/2022
    "It's not about the destination, it's the about the journey. And where is your journey taking you?"
    "... Not all who wander are lost!... --J.R.R. Tolkien
    Ottawa Ontario
    Quote Originally Posted by ptstew View Post
    Buy yourself a 2" 20' tow strap and loop it around the front 4" cross tube. Have the driver attach his hook through the tow strap. As the car is pulled up onto the flatbed keep you foot on the strap to keep it off the body work. I always keep one of these straps in the trunk. Scott
    https://www.speedwaymotors.com/Speed...SABEgKq8PD_BwE
    Dec 2012
    Houston, Texas
    Thanks, guys.
    st george, ut
    have the driver attach a strap to the control arm. he will need to put down blocks to drag it up onto his bed then have him strap it down using 8 point tie downs or D rings through the wheels.
    a 20' strap around the 4" cross tube wont work its too long and the drive wont use it or allow you to stand on it for insurance reasons
    Dec 2012
    Houston, Texas
    Had the car towed this week. Driver wrapped both lower control arms and pulled from leg of the Y formed. His truck bed was hinged about 6’ from the rear edge so that portion of the bed laid flat on the ground with the rest of the bed tilted. He then pulled car about half way on to the flat portion and then raised the bed back to being flat and pulled the car up. Worked really well. Thanks for all the feedback.
    Ottawa Ontario
    Quote Originally Posted by acmikee View Post
    Funny has worked for me with no issues?
