ptstew
My MK 1 Roadster is not running and needs to be towed. Are the front bumperettes strong enough to pull the car on to a rollback trailer? If not, where can I hook it without damaging the body?
Buy yourself a 2" 20' tow strap and loop it around the front 4" cross tube. Have the driver attach his hook through the tow strap. As the car is pulled up onto the flatbed keep you foot on the strap to keep it off the body work. I always keep one of these straps in the trunk. Scott
https://www.speedwaymotors.com/Speed...SABEgKq8PD_BwE
