Results 1 to 8 of 8
Thread: Heater hose connection to water pump
    Senior Member EZ$'s Avatar
    Feb 2014
    San Ramon, CA
    Trying to get all my plumbing taken care of before I start the wiring. I ran into a problem hooking up the heater hose to the water pump fitting. The problem is that it comes directly into the alternator, about 3 inches away. the hose will not make that tight a bend without kinking. Is there some way to make this bend that I'm not aware of? Last heater hose connection to make, and I'm snookered.
    Rick
    Nov 2016
    "The i.e." SoCal
    Feb 2014
    San Ramon, CA
    Thanks Frank. Wasn't sure that something like this was available. I'll check this out, and also with my local parts store. One of these days I hope to get this thing finished, and get that roll bar wired up.
    Rick
    Richard Oben's Avatar
    Kansas City MO
    All the old F 100 trucks use them. Some are even 3/4 tapered to 5/8. Just go to wall of hoses in the parts store. Richard.
    Feb 2014
    San Ramon, CA
    Thanks Richard, Today I'm off to the local parts store. I think I've reached the point where if I need it, I'm going to buy it and to hell with any thoughts of budget I may have started this build with! I just want to get it done.
    Rick
    Fairfax Station VA
    In addition to a 3/4" to 5/8" 90* hose elbow (https://www.napaonline.com/en/p/NBG10071), I used one of these: https://www.napaonline.com/en/p/NBG9924
    IMG_3461 by jhsitton, on Flickr
    MK IV Roadster #8631
    Feb 2014
    San Ramon, CA
    John, in addition to the hose I mentioned on the other forum, I looked at that 90 degree fitting. Once i start routing the hose, I may go back and pick one of those up to make the install cleaner. Didn't buy it thinking that I'd like to avoid as many joints as I can. Thanks for the reference to the part numbers.
    Rick
    Jax Beach, FL
    I did the same thing. 90* heater hose and a barb coupling.
