Thanks Thanks:  15
Likes Likes:  211
Page 3 of 7 FirstFirst 12345 ... LastLast
Results 81 to 120 of 271
Thread: SS383 Build - 33 Hot Rod #1134
    Jun 2018
    North Vancouver, BC, Canada
    Quote Originally Posted by peterh226 View Post
    The suspension mount holes continue to be a continuing source of confusion (at least to me).
    From a Gen 2 33 suspension thread (https://thefactoryfiveforum.com/show...272#post376272), Jim Schenck had the following to say about the upper and lower holes....
    The coupe and 818 have a street height set of holes and a low/race height set of holes an inch higher on the chassis. The truck and 33 have a standard height set of holes and a tall ride height set that are just under an inch lower. We added the holes on the 33/truck to help with extra clearance on the full fenders or if someone wants to add extra rake or run taller rear tires they can put just the back at the higher height.
    The key for all the cars is the higher holes equals lower ride height and lower holes equals higher ride height, which is not always intuitive with the chassis on jackstands.
    Gen 1 '33 Hot Rod #1104
    Jan 2019
    Mitchellville Iowa
    I wanted to get enough done with all of the body work that I understood the kinds of things I'd need to do to finish it off. At this point I want to see how some of the mechanical bits all fit in, so next step will be to remove the panels and work on the go-cart. The trunk opens and closes, the doors as well. Need to fit the pins for the bearclaws and the hood hinge once I get it (Still POL).
    Next step: Go-Kart.
    Attachment 111467 Attachment 111468 Attachment 111469 Attachment 111470 Attachment 111471
    Here's a couple of walk arounds as well
    Here's one where they are closed. https://youtu.be/pnEekz6y0j8
    Lots of stuff to learn...
    Peter,
    I’ve started bodywork on my Gen 2 and your build thread is very helpful.
    Did you doors look like this?
    Thanks Denny
    ?3C42DB7D-D437-43D7-8560-9C8A73FEC9CA.jpg3C42DB7D-D437-43D7-8560-9C8A73FEC9CA.jpg3C42DB7D-D437-43D7-8560-9C8A73FEC9CA.jpg17505FE4-9BFB-4138-8D29-A9395084BA11.jpg17505FE4-9BFB-4138-8D29-A9395084BA11.jpg
    May 2018
    Pinckney, MI
    Yup. Sanded down smooth and then added filler to finish it off. I used some of the really hard marine stuff to fill it since I need to cut it open for windows later on.
    - Peterh226 #1134
  4. Thanks Dduty thanked for this post
  5. #84
    Gatineau, Quebec, canada
    Was it glassed together underneath on the interior cavity? I had done that to provide the connection across the panel, mine is a Gen1 so I can see its different than this, this looks like a better setup if you have side windows or not.
    Andreas
  6. #85
    May 2018
    Pinckney, MI
    Gen 2 Lower Control Arm Installation Location
    I tried the lower holes, but they would not work with the lower control arms.
    • The Passenger side can droop (using upper hole).
    • The Driver side contacts the chassis and has no droop
    - Peterh226 #1134
  7. #86
    Jan 2019
    Mitchellville Iowa
    I had no problems with the lower holes. But my question is about which hole to use for connecting the coil overs to the upper control arm. The manual still shows the old style arm and doesn’t mention which to use. Most Gen2 builds I’ve seen use the top hole. One person at F5 thought the lower as right. Thoughts?
  8. #87
    May 2018
    Pinckney, MI
    Can you take a picture of your lower control arm at the chassis? As you can see in my picture there was no droop so no way it would work.
    For the Top Shock, I think either will be ok with a small difference in the ride height. I might move mine to the lower holes...
    - Peterh226 #1134
  9. #88
    Jan 2019
    Mitchellville Iowa
    Everything seems to have a good range of motion and no interference.
    I hope this is what you’re looking for.
  10. #89
    May 2018
    Pinckney, MI
    Where I'm having a concern is that I'm running full fenders so I should be using the lower mounting points to get some extra spacing to the fenders. But, it gets really tight and seems to have only about 3 inches of suspension travel. Most likely the engineer in me overthinking all of the geometry challenges. I think I'm going to try the lower holes for the lower arms with the bolts for the rear pivot pointing up (per Jim S) to get a little more clearance. I'm sure I'll be able to adjust the ride height with the spring preload later on (although that will be tricky to get to).
    Lot of opportunities for learning.
    - Peterh226 #1134
  11. #90
    May 2018
    Pinckney, MI
    Safety Wiring
    I know its overkill especially after some Loctite, but why not learn another skill along the way.
    - Peterh226 #1134
  12. Likes FF33rod liked this post
  13. #91
    Jun 2018
    Did the same thing, fun and it looks cool!
  14. Likes peterh226 liked this post
  15. #92
    May 2018
    Pinckney, MI
    Brakes and Steering
    First the Rear brakes. Mounted the adapter plate to the housing the other way to get enough clearance to the rotor. Aug25_1.jpg. Once the caliper is attached all looks OK. Aug25_2.jpg.
    Next, I mounted the front brake lines. First rivets in the chassis!! Aug25_3.jpg Aug25_4.jpg
    Got the steering all in and working. The effort is not as smooth as I'd like. It's not binding, but stiffens up. Nothing is hitting anywhere, just a bit of uneven torque is needed. Aug25_.jpg Aug25_6.jpg Aug25_7.jpg Maybe someone will see something unusual in the pictures.
    Also got the Pedal assembly mounted and ready to start on the brake lines.
    HINT: Put the D-Shafts in the freezer for a while to help them go into the universal joints a bit easier.
    - Peterh226 #1134
  16. Likes FF33rod liked this post
  17. #93
    May 2018
    Pinckney, MI
    Rear 3-Link Suspension - Spacers, Washers and Bolts - Oh My
    Found quite a collection of Bolts, Nuts, Washers, and spacers to make things fit in the rear. Here's some pictures of what it looks like right now.
    The top of the shock still needs spacers. Looks like a coarse thread for this one.
    One end of the link needs a washer.
    The other end of the link looks good
    I don't like the large washers for the shock, but the panhard rod looks OK.
    The lower arms were OK anyway!
    I'm going for a snug fit supporting the heims joints.
    Seems to be a mix of when to use washers under the head of bolts and nuts.
    I'm planning to use the fine thread bolt fo the lower rear shock mount to get enough length. Just need to find a couple of nuts to fit.
    Anyone else have fun installing the 3-Link?
    - Peterh226 #1134
  18. #94
    May 2018
    Pinckney, MI
    Hints - things I did.
    Added some fun to the garage: Signs.JPG
    Moser_recommended.jpg I was confused after read the various instructions about what to use in the Moser rear end I got through the FFR order. I sent a note to Moser and that is what they recommended and said no additive was needed and that it would take 2.5 quarts.
    Sept1_straps.jpg Here is how I both raised the rear into place and also use this to hold it close to where it will be once it sits on the ground. The straps make is easy to adjust the height.
    Sept1_Rad25.jpg I got some new .25in Spacers for the radiator. Seems to be just fine. Getting all of this stuff together was a bit of a struggle, but seemed to work out OK. Trying to get all the space I can for the radiator.
    - Peterh226 #1134
  19. Likes FF33rod liked this post
  20. #95
    May 2018
    Pinckney, MI
    Brake fluid reservoir
    I went with the OTB Gear triple reservoir as others have. I was hoping to have all lines hidden but I chickened out and have one line out the bottom. Guess I’m not as brave as Seth!
    So I created a template and then got the positioning I wanted. Measured about 20 times.
    Once attached, looks just fine.
    Need to finish routing lines, but should work just fine.
    - Peterh226 #1134
  21. #96
    I wish you’d said something. I have a jig for it.
    I OBSESSED over it for quite a while... ultimately, there’s so much crap you can’t hide it all! Yours looks great. No one will ever notice.
    Oh and the 3 link was a challenge. I got the wrong spacers more than once. But the customer service at HQ killed and we got it right.
    33 Hot Rod #1133. LS/TKO600
    Titled 2-28-20
    MkI.IV 2643k
  22. #97
    Kingwood Texas
    I like that Peter, think that I may go the same route. Does it clear your hood ok?
    33 HotRod #1142
    Started 5-9-19
    Kingwood, Texas
  23. #98
    May 2018
    Pinckney, MI
    Yeah, it's pretty close but OK. If you look at the top picture, the hood is positioned over the template.
    - Peterh226 #1134
  24. #99
    May 2018
    Pinckney, MI
    Seat mounting
    I’ve been thinking about how to mount the seats and wanted to flexibility and adjustments as I know vision out of this contraption will be challenging. So here’s where I’m at.
    I’m planning on a grade 8 bolt through the chassis (yikes) with some large load distributing washers below.
    Here are the parts I used
    https://www.summitracing.com/parts/tnk-sr400/
    Both from Summit.
    - Peterh226 #1134
  25. Likes Mrallsport32 liked this post
  26. #100
    May 2018
    Pinckney, MI
    Engine Installation
    Today was install the engine and see if things fit. There are a bunch of things for the interior (seat mounts) and other routing I want to plan. So, this is a test install and I'll probably remove it to do the floors and drill other stuff.
    The front clearance for one of the steering rack mount was going to interfere with the pulley so I ground it down a bit. I'm using a Blueprint 383 which has the March front mounts.
    I then created new spacers from galvanized pipe as my hardware store didn't have any stainless tube. I moved the engine back 1/2 inch total.
    I'm using the Flowtech headers and the downpipe attached just fine.
    Looks like it belongs here
    - Peterh226 #1134
  27. Likes Mrallsport32, TxMike64 liked this post
  28. #101
    Snug! Looks amazing. I almost wish I went sbc.
    Titled 2-28-20
    MkI.IV 2643k
  29. #102
    May 2018
    Pinckney, MI
    I like the old SBC look. The coil on plugs don't look good and I just don't like front offset distributors. I know the Coyote and LSX motors make a ton of power, but I've got more than enough with this and the Sniper should make it driveable with ease.
    That's the fun of these - lots of room for little (or big) things to make it your own.
    - Peterh226 #1134
  30. #103
    The newer engines are technical marvels and with the computer controls and power adders make reliable power with great fuel mileage. The LS versions are especially capable of making power at a reasonable cost. Hot rodders have been transplanting these engines in all sorts of cars and trucks and have been increasing power for years. You can find a lot of support in the aftermarket for them so it's no surprise they are so popular.
    And still that little SBC that first appeared in 1955 has a strong following today and can make plenty of reliable power for less $$ than most other engines. There is wide array of support in the aftermarket which helps drive down the cost of building one. And the SBC has the right period look in the Hot Rod if you want to run without a hood. Hard not to like the SBC for applications like these little cars where space is limited.
  31. Likes shmelty liked this post
  32. #104
    May 2018
    Pinckney, MI
    Seat risers and slides
    Got the seat mount figured out.
    I can reach the pedals!
    - Peterh226 #1134
  33. #105
    Jun 2018
    Good stuff Peter, how's the height with all those bits in there?
  34. #106
    May 2018
    Pinckney, MI
    Visibility Test
    I’m 5-7” so the height should help with forward vision. I’ll put the body on one of these days to check. I’ll add a picture then. But i played with it even higher and had room.
    Update! ******
    I put the body on and the top and clamped the seat in place. The picture out is a little higher than my view. I am thinking I will be looking out the upper areas of all of the windows.
    Here's the outside view. I attached the fenders so I could measure clearances for tires. A lot of money for those not to have them fit OK.
    - Peterh226 #1134
  35. Likes FF33rod liked this post
  36. #107
    May 2018
    Pinckney, MI
    Wheels and Tires
    Yikes! I measured the rear wheel wells and I've determined that 295 or 305 should fit just fine. Pretty sure I'm going with the AR605 Torq-Thrust M Chrome 17x8 in front and 18x10 in the rear. Looking for tires to fit is a pain! Not a lot of options if you want them to be a set.
    Options:
    Toyo Proxes 888
    235/45ZR17
    295/30ZR18
    Goodyear Eagle F1 Supercar 3
    295/3ZR18 (25 in OD)
    245/45ZR17 (25.7 OD)
    295/30 R18
    245/45 17
    The Toyo's are really race tires (I used to run BFG R1's and they were great on the track, not on the street). The Goodyears are more street friendly.
    Any comments from the illustrious peanut gallery? What have people actually been driving on (and sending up in clouds of smoke)?
    - Peterh226 #1134
  37. #108
    Front: TorqThrust 18x9-5.0" BS, Proxes R888 255/35ZR18
    Rear: TorqThrust 18x10-5.74 BS, Proxes R888 315/30ZR18 (will fit under full rear fenders)
  38. Likes shmelty liked this post
  39. #109
    May 2018
    Pinckney, MI
    Fuel System Planning
    I’ve got the FFR EFI kit as well as all the stuff from Blueprint for a 383 with the Sniper EFI. I like the idea of mounting it behind the waterfall so that is the plan. The quick disconnect at the fuel pickup has a really small outlet so I got a kit from Autozone to change it to 3/8. Then it will go through the filter, pump, filter, then to a bulkhead, then hard line to the base of the firewall, the AN-6 to a fitting with the pressure gauge and the on to the Sniper regulator.
    - do I need any more of a pressure regulator? Seems like this is ok from the diagrams.
    - 5/16 return line is the plan.
    - I’m planning to make the waterfall removable for servicing. 2 slots instead of holes.
    - Peterh226 #1134
  40. #110
    Jun 2018
    No, no regulation before the Sniper is needed.
  41. #111
    May 2018
    Pinckney, MI
    Cool. This should work out well then. On to fabrication!
    - Peterh226 #1134
  42. #112
    May 2018
    Pinckney, MI
    Fuel Tank
    Installed the fuel tank today. I was surprised to see how large the sump is for the fuel. Looks like some slosh will fill it up but the tank needs to be more than 1/3 full to keep the sump full. Not sure of the design of fuel tanks but it looks interesting.
    Here’s where I’m at. Any thoughts?
    - Peterh226 #1134
  43. #113
    Looks good. The pump is noisy. Fair warning. I would expect to need to insulate the waterfall. You’re assessment of the tank is right. I needed a couple of gallons of gas to keep the engine running on first start. Probably going to read empty with 2 gallons.
  44. #114
    May 2018
    Pinckney, MI
    Yeah. I was checking the clearance to the waterfall - Planning on Dynamat back there. Need to find a place to hang the evaporation canister. No mention of that in the instructions! I guess just need to hook up the pressure relief hose from the top of the tank.
    - Peterh226 #1134
  45. #115
    I hung the canister where the battery would go if it were underfloor. The hose goes from the vent to the evap.
    Titled 2-28-20
    MkI.IV 2643k
  46. #116
    I would suggest mounting the pump and filters underneath from where you have it so its accessible from below. We had already replaced a fuel pump as it ran dry briefly and it was toast so replacing it from below went fairly well. Where it is now you will need to pull off the waterfall, seats and hard top to gain access. Just a suggestion.
    This is where we mounted mine.
    Andreas
  47. #117
    Jun 2018
    Evaporation canister? do you mean a charcoal filter canister that some seem to make up? I didn't get anything like this in my kit....
  48. #118
    It’s in the efi kit....
    Titled 2-28-20
    MkI.IV 2643k
  49. #119
    Jun 2018
    might have disappeared when I deleted the FFR gas tank....
  50. #120
    May 2018
    Pinckney, MI
    Quote Originally Posted by sethmark View Post
    Does the orientation matter?
    Here’s what we’re talking about for anyone else reading this.
    - Peterh226 #1134
