Thread: Wilwood torque
    Mar 2017
    Norway / Merritt Island FL
    Wilwood torque
    Does anyone have the torque settings for the Wilwood IRS brakes?
    Sigurd
    Type 65 Gen 3, 347 Fi, Tremec, IRS, Wilwood, AC, PS
    Aug 2018
    Mead, CO
    I torqued the caliper mounts to 65 ft/lb using Loctite 271. I torqued the caliper to the mount at 40 ft/lb, but I did not use 271 per the instructions, I used blue 243, since the calipers will need to come off to replace pads.
    Mar 2017
    Thank you
    Sigurd
    Mar 2017
    Sorry, but I am not that used to the units. An M14 1|0.9 bolt should have 148 Nm or about 110 lb/ft. I think I am going to torque a little more than 65 lb/ft.
    Sigurd
    Aug 2018
    Mead, CO
    I am new to these builds, but 110 lb/ft sounds high. These bolts are going into aluminum and I would be concerned with stripping the material (may be unfounded :-)
    I reviewed 2 sets of instructions, the ones that came with the brake kit and Factory Five specific ones from the Wilwood website. The instructions that came with the brake kit said the mounting bracket should be 60 lb/ft and the calipers should be 35 lb/ft. The Factory Five specific instructions from the Wilwood website said 65 and 40, so I went with the higher value.
    Quote Originally Posted by Gadsden View Post
    I agree.
