Thanks Thanks:  3
Likes Likes:  3
Thread: Drive Shaft Adapter fitment question
    Apr 2019
    When I went to mount the driveshaft adapter, I noticed that it does not seem to fit properly with the differential.
    Attachment 105776
    The diameter of the gold adapter plate is too big to fit inside of the flange of the differential input shaft.
    Attachment 105814
    Attachment 105775
    Attachment 105815
    The manual states:
    "**There are two different Driveshaft adapters, one for center sections from automatic cars which is coated clear zinc.
    The Driveshaft adapter for center sections from manual cars is coated yellow zinc."
    Strangely the Silver/Clear coated adapter plate fits, but the Gold/Yellow does not fit.
    I guess it might be possible that one of the flanges was finished in the wrong color. But not both...
    What am I missing?
    I cant see any reason not to use the Silver Adapter.
    Jun 2018
    North Vancouver, BC, Canada
    I had the same problem. Ordered the IRS option from F5, they also supplied the driveshaft and gold adapter as well. Gold adapter didn't fit in the IRS flange. Called them and they sent the silver one, it fit....
    Cheers, Steve
    Gen 1 '33 Hot Rod #1104
  3. Thanks Rotopod thanked for this post
    Likes Rotopod liked this post
    Use whichever fits regardless of color.
  5. Thanks Rotopod thanked for this post
  6. #4
    Nov 2018
    Centennial, CO
    Confirmed. The only one I had was the silver one for my IRS setup and it fit nicely. The manual needs to be updated in a number of locations.
    Bradley
  7. Thanks Rotopod thanked for this post
  8. #5
    Apr 2019
    Thank you! I appreciate the feedback. Silver it is!
