Thread: Handbrake interference
    Mar 2017
    Norway / Merritt Island FL
    I have a interference problem between the coil spring and hand brake lever. Any suggestions to avoid this?
    I have rotated the spring so it works now, but I assume the spring will rotate in use. Turning the shock upside down will not help. Bending the actuating arm will help, but I am reluctant to do that.
    Suggestions?
    Sigurd
    Type 65 Gen 3, 347 Fi, Tremec, IRS, Wilwood, AC, PS
    Huntsville, Al
    yeah... rotating the spring will not fix that for good. - can you take picture or 2 from a little further back and give us a little more about the components you are using.... GEN 3 COupe?? looks like IRS... GEN 3... who's brakes... that doesn't look familiar to me
    Mar 2017
    Type 65 with IRS and the large Wilwood brakes.
    Sigurd
    wallace18's Avatar
    Trenton, Florida
    Can't tell from the angle of your photos , but is there a reason for that extra arm on the inside where the bolt holds the cable clip on top. ( first photo) If you can eliminate that it would move the bolt head towards the outside and give you the clearance. But that is just a guess from the photos above.
    Mar 2017
    Can't ell from the angle of your photos , but is there a reason for that extra arm on the inside where the bolt holds the cable clip on top. ( first photo) If you can eliminate that it would move the bolt head towards the outside and give you the clearance. But that is just a guess from the photos above.
    Good idea, did not think of that. The arm is designed for another type of cable end, a cylinder perpendicular to the wire.
    Sigurd
    Edmonton Alberta
    looks like you have a different caliper set up from what I have. Mine are the 13 inch Wilwood. I know the calipers are different for the IRS than the standard axle.
    the attached picture is not the greatest but you can see there are 2 callipers and they fit easily.
    other than this not sure how you fix it.
    David W
    Mkll 4874 built in 2004
    Mar 2017
    Problem solved: adjusted the camber from extreme negative to almost 0.
    Gentlemen, thank you for your input.
    Sigurd
    Huntsville, Al
    yeah I was just gonna say you adjustments looked bottomed out.
