Results 1 to 11 of 11
Thread: front brake line routing near coyote header?
    Mar 2018
    My father and I are ready to begin routing brake lines on our roadster. The consensus for rear brake lines is to route them inside the pedal box because FFR's routing on the front of the pedal box panel is too close to the coyote header. For the front brake line, FFR shows routing the line along the 3/4" tube right above the headers. Is this also a concern for heat? I've attached a picture of Fixits routing as an example (Thanks John!). Does anyone have a measurement from front brake line to the top of the header (see #1 in picture)? Also, does anyone have the measurement of the header to the front of the pedal box panel (#2 in picture)? I'm curious what the difference is.
    thanks
    MK IV Roadster-Delivered Nov '18
    Complete Kit, Gen2 Coyote, TKO 600, 2015 IRS, FFR brakes, FFR power steering, Full length headers
    Though I'm not Ford Powered, I had concerns too so I ran the front line down the inside of the upper tube since my headers are close too.
    You can see how I ran it 23-30 seconds into the attached video.
    https://youtu.be/_wnHDNgnNqs
    Good Luck From The Dark-Dart Side!
    O'Fallon, MO
    There is NO issue with running the brake line along the 3/4" tube. The brake caliper will be 50X hotter than the air at that location. You can hold your hand 2" away from a header.
    Grand Rapids, MI
    If it bugs you that much run it along the bottom of the upper 3/4” tube.
  5. Likes Ducky2009 liked this post
    Mar 2018
    Thanks. Routing the line on the upper 3/4" tube is an option we are considering. We're trying to hide as much brake line as possible so we would prefer to route it on the lower 3/4" tube. DOT3 boiling point is 284F. Headers can reach 500-600F during normal cruising (from what I've read). Would autocrossing be 900F? Maybe the air gap is large enough to lower the temp. I'll look into heat wrap or silica sleeve for the area nearest the header just to be safe.
    O'Fallon, MO
    Quote Originally Posted by Brian76 View Post
    Yes the headers can reach that temp, but the air flowing around them never will, and yes auto crossing could boil the fluid in the calipers, but that's not, always will. If you plan on racing, buy high quality brake fluid and change when needed.
    Run it on the top of the 3/4" frame, instead of at the side, (as shown in the picture), so the frame acts as a heat shield.
    Can't help with measurements as my headers are completely different.
  9. #8
    On a roll Al_C's Avatar
    Wheaton, IL
    How about this? Run the brake line along the upper frame rail. They aren't the best photos, but these should give you an idea.
    This approach requires a few extra bends, but it takes the header completely out of play.
  10. #9
    Nov 2012
    Tacoma, WA
    Like Rich said the air temp where the brake line is will never get very hot even will sitting in traffic. I would be surprised if that line got above 150 degrees itself. The coyote runs pretty cool. Keeping it as is would be fine or you can run it like Al suggested, that is how I have mine ran.
  11. #10
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    You could cover them in a heat shield sleeve for a little extra protection:
    https://www.heatshieldproducts.com/hot-rod-sleeve
  12. #11
    Mar 2018
    Thanks for the recent replies. As mentioned, we are considering routing the brake line on the top 3/4" tube but we prefer the lower 3/4" tube to hide brake line as much as possible in the engine compartment. More than likely this isn't an issue. But now I'm curious so I might experiment with my 87 foxbody and a IR thermometer just to see how hot the brake line material gets at various air gaps.
    John, thanks for the link. I think a couple of those products would do the trick.
