Results 1 to 3 of 3
Thread: Power Steering
Hybrid View
    Senior member
    Carlsbad,Ca
    Power Steering
    I am building an 818C and have decided to install power steering.
    Problem is when I started the build I stripped all the lines off the rack and
    threw them away, now I need them and wonder if anyone has the lines they
    removed from the rack. Thanks for any help !
    Feb 2019
    Houston, TX
    Have you considered an EPAS unit from a Prius? That would eliminate the power steering pump, lines running front to back, and all that fluid that could start leaking.
    wallace18's Avatar
    Trenton, Florida
    The 818 is so light you really do not need P/S, IMO. However using a Saturn Vue unit is also an electric alternative that is cheap from a bone yard.
