Results 1 to 3 of 3
Thread: Power Steering
    Senior member
    Carlsbad,Ca
    Power Steering
    I am building an 818C and have decided to install power steering.
    Problem is when I started the build I stripped all the lines off the rack and
    threw them away, now I need them and wonder if anyone has the lines they
    removed from the rack. Thanks for any help !
    Feb 2019
    Houston, TX
    Have you considered an EPAS unit from a Prius? That would eliminate the power steering pump, lines running front to back, and all that fluid that could start leaking.
    The 818 is so light you really do not need P/S, IMO. However using a Saturn Vue unit is also an electric alternative that is cheap from a bone yard.
