42
170
So I decided not only to fibreglass the inside of the door, but on the drivers side ( because it was quite thin) I fibreglassed in a 9 or 10” long chunk of 3/16” flat bar to support the lower hinge. It stops roughly half way up the door.
The passenger side door was a little bit thicker so just used fibreglass. Will install it tomorrow.
Drivers side..,
Passenger side...
