Thanks Thanks:  42
Likes Likes:  170
Page 13 of 13 FirstFirst ... 3111213
Results 481 to 499 of 499
Thread: Pat’s Truck, back to the Turbo, see post 497
  1. #481
    Sep 2019
    Houston, TX
    Hmmm. Was the lip on the seal in your hand facing the right direction?
  2. Thanks Pat Landymore thanked for this post
    Likes Pat Landymore liked this post
  3. #482
    Senior Member Pat Landymore's Avatar
    Dec 2018
    SW Calgary, AB
    …Aaand we have a winner!
    Yes McGuyver, you are correct. The block (top) half was correctly installed and the cap (bottom) half was not.
    What still has me a little bit concerned is it wasn’t leaking under pressure from the shop vac (2 psi) around the entire bottom of the seal…it was leaking where the two Mis-matched ends met up.
    There is only one person to blame…and this is his build blog… 🙈🙈🙈
    Once again with an 88 mm Turbo, Big Block Chevy powered, ‘35 Hot Rod Pickup
  4. #483
    Dec 2018
    SW Calgary, AB
    Very embarrassing to admit my mistake…I’ve rebuilt engines ranging from lawnmowers, motorcycles, normally aspirated and turbocharged aircraft engines, farm equipment…to a wide variety of V8 American engines from almost all makes.
    Never…ever have I done something dumb like this.
    Oh well, the longer one lives the more they get to learn! 😊👍🏼
  5. Likes FF33rod liked this post
  6. #484
    Aug 2019
    Alvin, Texas
    You cant make a mistake if you don't do anything. Glad you found it.
  7. Thanks Pat Landymore thanked for this post
  8. #485
    Dec 2018
    SW Calgary, AB
    Well, he’s back in. Was a somewhat ghastly job on my own…but my pals are always too busy today, this weekend, this week. I just want to get it back together so…
    First photo is my brand new idea to support the trans…no thoughts as to why it didn’t occur previously! One hose clamp on each lower frame rail and a chunk of pipe plus appropriate wood to make up the distance.
    And here’s the engine mostly back in place with the passenger side header installed:
    The drivers side exactly as before…minus the crossover for the turbo…
    Now taking the rest of the day off! 😁
  9. Likes FF33rod, ztoolman44 liked this post
  10. #486
    Dec 2018
    SW Calgary, AB
    A Summit racing order with all the goodies to craft up a muffled, Vee Band attached ‘weedburner’ dual exhaust system will arrive either Wednesday or Thursday. Hopefully I'm quick enough at fabrication to have it running by the end of next weekend.
    That should give me plenty of time for 4x vicious to install transmission bolts and connect/test the rest. 👍🏼👍🏼
  11. #487
    Dec 2018
    SW Calgary, AB
    As always seems to be the case with any hot rod…mine is suffering from ‘scope creep’.
    First off, I needed to remove the seat, shifter cover, some carpet and the trans cover to get all the engine->trans bolts back in. While all that was apart I started thinking…why am I leaving a $$ water meth system on a truck with 8.5:1 compression? So off that came.
    Now working at moving two fuel lines on the drivers side for better clearance to the DS exhaust. Seems to me those two items don’t play well together… LOL 😂
    All of the new exhaust is mocked up on jack stands but only about 1/3 welded until final-final fitment confirmed.
  12. Likes FF33rod, ztoolman44 liked this post
  13. #488
    Dec 2018
    SW Calgary, AB
    Well, she’s done…almost…I hope! 👍🏼
    Have a brand new minor coolant leak that needs attention and possibly a small trans fluid leak…but much closer.
    Will be putting it up on an internet auction website within the next two weeks with a reserve bid and see what happens.
    Photo of the exhaust system under construction, just ahead of finish welding…
    A photo of how the truck looks now…
    She’s a fair bit louder than I anticipated. I’ve become accustomed to the ‘spinny muffler’ effect that a turbo has…kind of underestimated how much muffling is required! That said, the sound definitely suits the rat rod theme.
    Auction website web link:
    https://formulaauctions.com/auctions
  14. Likes McGuyver, ztoolman44 liked this post
  15. #489
    Dec 2018
    SW Calgary, AB
    The auction guy came over last evening and took lots of photos.
    My auction runs June 3 to June 12.
    Fingers crossed! 🤞🏼
  16. Likes ztoolman44 liked this post
  17. #490
    Aug 2019
    Alvin, Texas
    Good luck!
  18. Thanks Pat Landymore thanked for this post
  19. #491
    Dec 2018
    SW Calgary, AB
    A start up and ride along video taken a few days ago…
    https://m.youtube.com/watch?v=nsrcPM...ature=emb_logo
  20. Likes McGuyver, RuffShod, ztoolman44 liked this post
  21. #492
    Senior Member Robodent's Avatar
    Aug 2018
    Hampshire, IL
    Nice video Pat! Your engine sounds great . I can remove a dent from a vehicle without painting it but I wish I was more tech savvy to make videos and post them on the web . Nice job. Rob.
    FFR 35 p/u # 0016 Dart 347 TKO 600
  22. Thanks Pat Landymore thanked for this post
  23. #493
    Dec 2018
    SW Calgary, AB
    Here’s a fun photo!
    Taken last evening by a buddy that I’ve known for over 40 years…of his son chaperoning me home in Ms 35 from a car meetup at a local burger joint.
    The kid is only 20 years old…very respectful of my vehicle but at the same time anxious to lean on it when (honorary) Uncle Pat said…’dang it boy…just punch it!’
    An awesome moment for me…he was blown away by big block torque. 😁
    Afterwards we all walked over for beers and food at a local pub…and be hanged if my honorary nephew didn’t insist on paying for all of us for privilege of driving!
    Major Kudos to my friend Michael and his wife for raising such an awesome son! He’s in 3rd year automotives so I think with that attitude he’ll be set for the rest of his life. 👍🏼👍🏼
    Last edited by Pat Landymore; 06-04-2022 at 06:03 PM. Reason: Correct grammar etc…
  24. Likes ztoolman44 liked this post
  25. #494
    Dec 2018
    SW Calgary, AB
    So she’s sold, in my city.
    Onwards to other things 😊😁👍🏼
  26. Likes ztoolman44 liked this post
  27. #495
    Sep 2019
    Houston, TX
    Congrats and enjoy whatever comes next!
  28. Thanks Pat Landymore thanked for this post
  29. #496
    Aug 2019
    Fort Lauderdale
    great pic and congrats; look forward to seeing you back here with another project
  30. Thanks Pat Landymore thanked for this post
  31. #497
    Dec 2018
    SW Calgary, AB
    So everyone following my posts knows how much trouble I had trying to sell 35 as a turbocharged big block hot rod.
    So I whipped up a nice dual exhaust, put in an N/A tune, installed a conventional air cleaner and put her in the online auction.
    The gentleman that purchased her paid me almost what I was initially asking when she was turbocharged…plenty of generous bidding all around.
    When he came to pick it up last Thursday (??) we were discussing the history of my build…and when he found out she used to be turbo’d he was SO enthused!! He offered me extra $$ to re-install the turbo system, which I declined as he paid me fairly.
    Long story short, I spent my weekend going ‘back to the future’ and turning 35 back into my original vision for her.
    He’s picking it up tomorrow. Will discuss with him how and when it’s ok to get ‘western’ with the loud pedal…don’t want him to scare himself or wrap the old gal up.
    I know I wouldn’t have had nearly as many bidders, or as high a bids if I advertised her as turbo’d….just goes to show that one never knows how these stories end until they do! 😁
    So for my final posting, here she is ready for pickup….
  32. Thanks edwardb thanked for this post
    Likes FF33rod, Chopper, RuffShod, ztoolman44 liked this post
  33. #498
    Jun 2018
    North Vancouver, BC, Canada
    Interesting twist....
    Gen 1 '33 Hot Rod #1104
  34. Thanks Pat Landymore thanked for this post
  35. #499
    Dec 2018
    SW Calgary, AB
    Hello everyone!
    I see there are quite a few ‘hits’ per week on my old build thread.
    Sincerely hope it’s helpful.
    If anyone has any questions, please don’t worry about PM’ing me or simply posting your question here. Happy to read and reply.
    Main reason I dropped back in…will be making a post tomorrow as to what I’m up to now in the “Off Topic” section. Still doing cars…plural…not FFR for the time being…more like where the kits were born from.
    There’s your click bait!
    Ha 😆
  36. Likes McGuyver liked this post
