Thanks Thanks:  42
Likes Likes:  170
Page 4 of 13 FirstFirst ... 23456 ... LastLast
Results 121 to 160 of 499
Thread: Pat’s Truck, back to the Turbo, see post 497
  1. #121
    Senior Member Pat Landymore's Avatar
    Dec 2018
    SW Calgary, AB
    Thanks for the suggestion Ralph, I’ll consider it. Want to try again today with a different shape of shim, as knowing my fibreglass work, the shim will look a lot better. LOL
    I’m a bit spooked about cutting the doors so the windows and rubber will fit correctly...those cuts seem a lot more irreversible than the work I’ve been doing so far.
  2. #122
    Dec 2018
    SW Calgary, AB
    So I spent a chunk of today on ( no surprise here...) the doors.
    I think I’ve come up with a better way of getting them more or less right. My drivers side door I fibreglassed plus 3/16 steel on the lower inside. I had only fibreglassed the inside of the passenger door. I tried a couple of different shims between the door and the hinge, not getting much further.
    After more frustration I took it all apart again. Today I cut the front door bracket, bent it so it fits the front of the door correctly, welded it back up and bolted it all back together with my thinnest shims between hinge and door. Passenger side door works quite well now!
    Front passenger side door bracket before modification:
    After modification:
    It fits well now top and bottom at the front of the door plus the carriage bolts at the rear line up nicely too.
  3. #123
    Dec 2018
    SW Calgary, AB
    I also cut both doors to get an appropriate space for the window rubbers plus the window.
  4. #124
    Loveland, CO
    Pat, what gap did you aim at around the door glass fitting area? Same gap all the way around?
    Thanks, Ralph
  5. #125
    Dec 2018
    SW Calgary, AB
    I’m starting with what I believe is a bit small... 0.67-0.69”.
    Doing the same everywhere until I learn more.
  6. #126
    Dec 2018
    SW Calgary, AB
    I couldn’t handle working on the doors two days in a row, particularly after a nice box of parts from Summit arrived this morning. LOL
    So instead I installed the heater core that arrived, wired it and installed my defroster vents. I think it was the weatherman’s fault as he’s been telling us we’re down into the minus 30’s C by the weekend.
  7. #127
    Dec 2018
    SW Calgary, AB
    Will try reloading the photos again...right way up
  8. #128
    Dec 2018
    SW Calgary, AB
    Dec 2018
    SW Calgary, AB
    Wow, I think I’ve finally conquered my doors!
    A week of being frozen out of my garage, another week of goofing off, finally got back to it.
    What i did is changed my game plan. Please see attached photos, I think they will explain my logic...
  10. #130
    Dec 2018
    SW Calgary, AB
    Once I had the hinges in alignment by this method, the passenger side door evolved quickly to fit well. The drivers side...ahem, I tried playing by the rules to no avail. Finally fabbed up a roughly 3/16” spacer between the lower hinge and the door, reinstalled it, loosened the hinge attachment points inside the cab, gave everything a shake and retightened the hinge attachments. It’s an 80-85% fit now. Good enough for me to move onwards. I can tweak in a year if I feel like it.
  11. #131
    Loveland, CO
    Pat, I used a long threaded rod to slip between my door hinges to line up (yours looks like a wooden dowel), same principal. We struggle, but come up with similar ideas.
    I may go out to the garage today to think about my doors. I have been letting them "simmer" for the past two weeks, hoping they will straighten themselves out. I like your idea of waiting a year to finalize. You have to get to the other assembly items.
    Keep us advised.
    Ralph
  12. #132
    Dec 2018
    SW Calgary, AB
    I did a random item on the truck that has been bothering me for a long time, making supports for the rear fenders.
    Photo below.
    Yes, they are pop riveted to the fenders...for now. When I remove the box next time I’ll fibreglass them in, drill out and fill the pop rivet hole.
    On the bright side, the fenders are much more solid now.
  13. #133
    Dec 2018
    SW Calgary, AB
    Per my question on the other thread, I also drilled drainage holes in my doors today.
  14. #134
    Dec 2018
    SW Calgary, AB
    I’m completely moving on from the doors for now but still have them sticking out a bit at the bottom.
    Will figure it out eventually.
  15. #135
    Loveland, CO
    That ample "C" clamp should hold them in nicely.
    We are still having fun.
    Ralph
  16. #136
    Dec 2018
    SW Calgary, AB
    LOL!
    It’s been very handy for many things on this build
  17. #137
    Dec 2018
    SW Calgary, AB
    I’ve decided the time has come for me to build my Big Block and Powerglide. I’ve had the components for a while now...it feels like time for a (FUN!!) change.
    Will be about 2 weeks in total, plus the rest of my turbo kit.
    First I had to take it back out by myself...
  18. #138
    Dec 2018
    SW Calgary, AB
    Prior to that I removed heads intake etc that I had mocked up.
  19. #139
    Dec 2018
    SW Calgary, AB
    Then out it came and on to the engine stand. I had the block fully machined previously and have an Eagle rotating assembly plus a full Trick Flow 280 cc top end kit. Hopefully everything plays nicely together and this part of my build will progress quickly.
  20. Likes shmelty liked this post
  21. #140
    Dec 2018
    SW Calgary, AB
    Unless there is a huge mistake in some vendors machining; engine, trans and turbo kit will be all home built.
  22. Likes shmelty, ztoolman44 liked this post
  23. #141
    Aug 2019
    Alvin, Texas
    Did you change the front springs to handle the weight of the big block?
  24. #142
    Dec 2018
    SW Calgary, AB
    At this point I haven’t.
    My reasoning is that everything, except the block, will be aluminum and I’m using a Powerglide trans which is far lighter than 700R4,4Lxx and 6Lxx transmissions.
    My guess is my big block combo will weigh in similar or less than an iron small block (or iron block LS) with the much heavier transmission. I have a scale for my chain hoist so will have accurate weight once the engine is assembled. Ill post its weight here in my build thread.
  25. Likes shmelty liked this post
  26. #143
    Dec 2018
    SW Calgary, AB
    A couple of decent days building Mr Big Block. I think I’ll be done tomorrow other than installing the oil pump pickup tube and final bolt up of the pan. Waiting on Amazon for delivery of the tool for that job... Setting up the valve train in the morning. Hopefully on to my transmission the day after.
  27. Likes shmelty liked this post
  28. #144
    Aug 2019
    Alvin, Texas
    Lookin good!
  29. #145
    Dec 2018
    SW Calgary, AB
  30. Likes shmelty liked this post
  31. #146
    Dec 2018
    SW Calgary, AB
    So on to the transmission.
    I’m going to take a day or two off to allow my garage ( and me) to de-fumigate from all the solvents used to prep my engine build.
    The chain hoist was used up as I couldn’t move my big block out from underneath it so had to get a bit creative and lift the transmission by myself onto the engine hoist.
    The three stages of lifting something an older guy like me probably shouldn’t be lifting on his own LOL
  32. #147
    Dec 2018
    SW Calgary, AB
    All ready for installing a shift kit and deep sump pan on the transmission tomorrow.
    Flexplate and torque converter to follow after that.
  33. Likes shmelty liked this post
  34. #148
    Dec 2018
    SW Calgary, AB
    Wow, sometimes the aftermarket gives, and all too often it takes away. Today was definitely in the latter category.
    Tried installing the flexplate today but there was a bolt that fought me. Had to run the 7/16” NF tap through a brand new, $900.00 crank to get it to fit. Then the flexplate didn’t have enough radius for my ARP flexplate bolts, so 20 minutes of radiusing and cleaning everything up later it all fit correctly. Brand new parts...
    Then, I fully opened my nice new (brand name deleted) shift improver kit, only to discover there is a ‘servo spring’ listed in the “what this kit contains” list and of course included in the kit...but nary a word of instruction OR the required gasket for the cover to replace the one that will inevitably crack when I remove it.
    What the heck?!
    Are these people Neanderthals??
    Thank goodness it’s Valentine’s Day and I can take my wife out for dinner, a drink and conversation not relating to car stuff.
  35. Likes FF33rod, shmelty liked this post
  36. #149
    Dec 2018
    SW Calgary, AB
    The adventure continues...
    So I taught myself about all the things that could go wrong changing the servo spring and got that done this morning.
    Then I removed the tailshaft housing and replaced the bushing and the ( red locktighted in ) tailshaft seal.
    On to the actual shift kit. I hit the point in the instructions where I’m supposed to drill the separator plate at locations marked ‘B’ but no where in the instructions is something that tells me where B is!
    Wow...
    I’ve emailed the manufacturer after finding my instructions are basically the same as, and newer than, what is online. Hopefully they get back to me soon. If not I’ll do some research and just make my own shift kit.
    Meantime I’m going to take a couple of days off from this project.
  37. #150
    Senior Member ztoolman44's Avatar
    Apr 2019
    Summerland, BC
    Some days are like that. Its not just you.
  38. #151
    Dec 2018
    SW Calgary, AB
    Thanks!
    A great reminder that I’m not alone in this hot rodding adventure
  39. #152
    Aug 2019
    Alvin, Texas
    Looks like you are havin fun!!!
  40. #153
    Dec 2018
    SW Calgary, AB
    Transmission completed and joined up the the engine.
    Back to working on the truck...
    Last edited by Pat Landymore; 02-20-2020 at 09:45 AM. Reason: Re rotate photo to correct orientation
  41. Likes shmelty liked this post
  42. #154
    Dec 2018
    SW Calgary, AB
    And the final weight of engine and transmission is...
    661 lbs incl the converter filled with ATF.
  43. Likes shmelty liked this post
  44. #155
    Dec 2018
    SW Calgary, AB
    Spent bits n pieces of the last couple days running hard line in a few different places
  45. #156
    Dec 2018
    SW Calgary, AB
    And starting in on my High Tension ignition wiring...
  46. #157
    Loveland, CO
    Tranny lines to front? Where do you plan to put your cooler? Or, are they just temporarily pointing in that direction?
    Ralph
  47. #158
    Dec 2018
    SW Calgary, AB
    Howdy Ralph:
    You’ll see in the coming weeks. The cooler will be mounted in front of the radiator.
    Pat
  48. #159
    Dec 2018
    SW Calgary, AB
    Its going to get crowded on the right hand side of the engine area as my build progresses...
  49. #160
    Dec 2018
    SW Calgary, AB
    Today I fabricated and installed seat risers, approximately 3” high. Will post photos of those tomorrow, I’m inside now.
    The other major work was removing the front end bodywork and disassembling the front suspension.
    Two reasons; first, to install my new longer lower suspension hinge points (longer tabs), and second, to install a QA1 bump steer kit.
    I’m doing this because the ride height of this truck will be higher than recommended. I used a Foxbody Mustang kit as a lot of the front suspension in the truck is simply is bass ackwards compared to a Mustang, so it’s perfect.
    Those boys use this kit to fix bad suspension angles when they lower a car, I’m using it for correction because I’m raising mine!!
    It looks so far like it will work as planned.
    I know I may be wrong doing this but my hunch-o-meter tells otherwise to going to give it a shot.
