Page 2 of 2 FirstFirst 12
Results 41 to 51 of 51
Thread: Trunk Support Kit for MK4
    Quote Originally Posted by swwebb View Post
    Here are some pictures. The prop rod has mounts that were made by another member of the forum that screw onto the top of the frame rail. They were installed on a finished trunk with the carpet installed.
    Attachment 106352 Attachment 106353 Attachment 106354
    Do you have the contact info for the other member who made the parts to mount and retain the rod? I really like the look of this set up and would gladly pay him for these pieces.
    Thanks!
    Bill
    Dec 2013
    Sandia Park, NM
    Bill,
    I'll contact him to see if it's OK to give out his info.
    FFR #8305; IRS, 347; T5 Trans; EFI, 3.27 Rear; 17x9" Front; 17x10.5" Rear
    Paint - Ford Magnetic Metallic Gray (J7) with Black Stripes; Painted by "da Bat"
    Complete Kit Delivered 05/15/2014; Titled and Registered 4/14/2017 as a 1965!!
    Bill,
    Thank you sir!
    mburger's Avatar
    Punta Gorda FL
    My ol’ Mk1 came with this fancy trunk lid support.
    Mark
    Nov 2016
    Petaluma, CA
    I got this simple prop rod from Lokar. Fabbed a bracket and all seems to work well. Just my 2 cents. Joel
    Senior Member karlos's Avatar
    Aug 2013
    Littleton, CO
    Bill,
    Interested as well. Assuming you get the ok, can you include me too, please?
    Thank you.
    -Karl
    MKIV Roadster #8641
    Complete Kit with IRS, Eaton Detroit Truetrac, 3.55 gears, Wilwood Brakes
    Ford Racing Z427 w/ Pro-M Sequential Port EFI System
    TKO 600 + McLeod Midshifter; Fast Freddie's Electro-Hydraulic power steering
    Miller Customs Bodywork & Paint
    Dec 2013
    Sandia Park, NM
    Quote Originally Posted by bilwil View Post
    Thank you sir!
    For info on the modified prop rod supports, contact Dave Albertalli - his email is [email protected].
    He's not on this forum much - mostly on the other one.
    Thanks!!! I just sent him an email!
    Bill
    Bill
    Awesome fast service. My new prop rod mounting kit arrived this weekend and I will be installing it this weekend!
    Will post pics as soon as I finish it.
    Thanks!
    Bill
    So what prop rod will you use for it? Are the mounts designed for a pre-existing rod you can purchase?
    a decent solution for mounting it.
    Dec 2013
    Sandia Park, NM
    The prop rod mounting kit from Dave Albertalli is made for Breeze's trunk prop rod
    https://www.breezeautomotive.com/sho...steel-30-long/
    as mentioned in my earlier posts #12 and #26.
