Bill,
I'll contact him to see if it's OK to give out his info.
FFR #8305; IRS, 347; T5 Trans; EFI, 3.27 Rear; 17x9" Front; 17x10.5" Rear
Paint - Ford Magnetic Metallic Gray (J7) with Black Stripes; Painted by "da Bat"
Complete Kit Delivered 05/15/2014; Titled and Registered 4/14/2017 as a 1965!!
My ol’ Mk1 came with this fancy trunk lid support.
Mark
I got this simple prop rod from Lokar. Fabbed a bracket and all seems to work well. Just my 2 cents. Joel
MKIV Roadster #8641
Complete Kit with IRS, Eaton Detroit Truetrac, 3.55 gears, Wilwood Brakes
Ford Racing Z427 w/ Pro-M Sequential Port EFI System
TKO 600 + McLeod Midshifter; Fast Freddie's Electro-Hydraulic power steering
Miller Customs Bodywork & Paint
For info on the modified prop rod supports, contact Dave Albertalli - his email is [email protected].
He's not on this forum much - mostly on the other one.
The prop rod mounting kit from Dave Albertalli is made for Breeze's trunk prop rod
https://www.breezeautomotive.com/sho...steel-30-long/
as mentioned in my earlier posts #12 and #26.
