All - Looking for some guidance on what fittings are needed for the hose connections to the FFR power steering rack.
Mk4 #9165, Base Kit with lots of options, Delivery on 08/17/2017, Coyote, TKO600, 2015 IRS, 18" Halibrands, 12.99" Wilwoods
Mark at Breeze should be able to help you out. Looks like he sells a complete kit. Scott
https://www.breezeautomotive.com/sho...-steering-kit/
Give Mark at Breeze a call, he hooked me up with every thing I needed.
JR
good tips.
thanks,
Mark
Another satisfied Breeze customer here. After a quick description of what I was trying to accomplish, Mark hooked me up with everything I needed.
MK IV Roadster #8631
Just curious, what size hose are recommended for the lines that run to the rack AN6 ?
For a Fox rack/OEM pump, i adapted to AN with some Russell fittings - they were aluminum and i though it might be kinda dicey given they could see 2000-3000 psi in the line but so far no problems. PNs i used with a fox rack...
RUS-648020 and 030 ($23 for both)
I then fab'ed one of the Russell powerflex hoses to feed the pressure line to the rack - worked great for me
So AN6 is the suggest hose size ?
AN6 is plenty big.
