Results 1 to 10 of 10
Thread: Fitting for FFR Power Steering Rack
    Senior Member mlewis's Avatar
    Mar 2017
    Groton, Massachusetts
    All - Looking for some guidance on what fittings are needed for the hose connections to the FFR power steering rack.
    Mk4 #9165, Base Kit with lots of options, Delivery on 08/17/2017, Coyote, TKO600, 2015 IRS, 18" Halibrands, 12.99" Wilwoods
    Ottawa Ontario
    Mark at Breeze should be able to help you out. Looks like he sells a complete kit. Scott
    https://www.breezeautomotive.com/sho...-steering-kit/
    Senior Member jrcuz's Avatar
    Stafford Virginia
    Give Mark at Breeze a call, he hooked me up with every thing I needed.
    JR
    Mar 2017
    good tips.
    thanks,
    Mark
    Jun 2015
    Fairfax Station VA
    Another satisfied Breeze customer here. After a quick description of what I was trying to accomplish, Mark hooked me up with everything I needed.
    MK IV Roadster #8631
    Mar 2017
    Just curious, what size hose are recommended for the lines that run to the rack AN6 ?
    Junior Member Tacojoe's Avatar
    Mar 2019
    For a Fox rack/OEM pump, i adapted to AN with some Russell fittings - they were aluminum and i though it might be kinda dicey given they could see 2000-3000 psi in the line but so far no problems. PNs i used with a fox rack...
    RUS-648020 and 030 ($23 for both)
    I then fab'ed one of the Russell powerflex hoses to feed the pressure line to the rack - worked great for me
    O'Fallon, MO
    Quote Originally Posted by Tacojoe View Post
    Not sure where you got the pressure info from, but a Ford pump typically will run about 750psi, the pressure release valve is 1400-1500psi.
    Mar 2017
    So AN6 is the suggest hose size ?
    O'Fallon, MO
    AN6 is plenty big.
