Results 1 to 10 of 10
Thread: Fitting for FFR Power Steering Rack
    Senior Member mlewis's Avatar
    Mar 2017
    Groton, Massachusetts
    All - Looking for some guidance on what fittings are needed for the hose connections to the FFR power steering rack.
    Ottawa Ontario
    Mark at Breeze should be able to help you out. Looks like he sells a complete kit. Scott
    https://www.breezeautomotive.com/sho...-steering-kit/
    Senior Member jrcuz's Avatar
    Stafford Virginia
    Give Mark at Breeze a call, he hooked me up with every thing I needed.
    JR
    Mar 2017
    good tips.
    thanks,
    Mark
    Fairfax Station VA
    Another satisfied Breeze customer here. After a quick description of what I was trying to accomplish, Mark hooked me up with everything I needed.
    MK IV Roadster #8631
    Mar 2017
    Just curious, what size hose are recommended for the lines that run to the rack AN6 ?
    Junior Member Tacojoe's Avatar
    Mar 2019
    For a Fox rack/OEM pump, i adapted to AN with some Russell fittings - they were aluminum and i though it might be kinda dicey given they could see 2000-3000 psi in the line but so far no problems. PNs i used with a fox rack...
    RUS-648020 and 030 ($23 for both)
    I then fab'ed one of the Russell powerflex hoses to feed the pressure line to the rack - worked great for me
    O'Fallon, MO
    Quote Originally Posted by Tacojoe View Post
    Not sure where you got the pressure info from, but a Ford pump typically will run about 750psi, the pressure release valve is 1400-1500psi.
    Mar 2017
    So AN6 is the suggest hose size ?
    O'Fallon, MO
    AN6 is plenty big.
