Thread: Autometer gauges-coyote motor-oil temp hook up
    Lake Mills, WI
    Hi Guys,
    I'm running autometer gauges(amps, fuel, oil temp, oil pressure and water temp) and a 2017 coyote motor.
    I have found where I hook up the oil pressure and water temp.
    the coyote manual says nothing about where to hook up the oil temp.
    Any input is appreciated
    Thank you
    Martin
    Raleigh NC, OIB NC
    What oil pan do you have?
    Kevin
    MKIV #8234
    Lake Mills, WI
    aluminum low profile moroso
    I think I just figured it out. use the same sending unit as the one for the water temp
    M
    Quote Originally Posted by magicmarto View Post
    M
    No, that would just give you two gauges reading the water temperature. Does your pan have an unused bung? If so that's where you would put the sender for oil temp. If you are using a remote filter the adapter will often have a port that will accept a sender, or if not it could be drilled and tapped for one.
    Raleigh NC, OIB NC
    M
    MOROSO pans have multiple bungs use one of them for the oil temperature sender.
    You many need an adapter to match the pans threads to the senders threads. Got mine at Home Depot. I just used the bung closest to the senders wire lead plug.
    Kevin
    MKIV #8234
    Lake Mills, WI
    yup
    Same pan as mine
    Will do
    Thanks guys
    Martin
