Results 1 to 3 of 3
Thread: 700r4 transmission speedometer plug
    Senior Member colsen23153's Avatar
    Jan 2019
    Sandy Hook, Virginia
    What size plug do I need to replace the speedometer cable drive on a 700r4 transmission? It was suggested I use a freeze plug.
    Cliff
    '33 Hot Rod Chassis #1118, Gen 2, hard top, bike fenders, AC, electric steering. BluePrint Engines Chevy 383 Fuel Injected with the 700R4 transmission 8.8" rear 3.55.
    Senior Member Tampa33Build's Avatar
    Feb 2017
    Lutz, Florida
    I tried several sizes, either too big or too small. I forget what the caliper measurement was but I could not find one that matched the measurement. I ended up buying a "4L60E 4L60 700R4 Transmission VSS VEHICLE SPEED SENSOR".
    Jan 2019
    I found a rubber expansion plug on eBay. (Dorman Expansion Plug 02607) It makes a good fit.
    Cliff
