Does anyone know of a place to get custom steering shafts made.
I have the ffv shaft and ffv power steering rack. I had the lower end shortened a inch so that it would fit with the bearings on the outside of the firewall because it didn’t want to fit on the inside because of the coyote pedal.
I recently installed a breeze automotive quick release steering wheel. When I put the top end inside the lower part with the spring washer it stopped sliding in a couple inches before it was in far enough. I figure that the washer got jammed. I could have swore that I put it in with the washer point away from the center.
Now I can’t get the top (inside) out of the tube. I tried pulling. And then tried using a slide hammer with some success but not enough. I am afraid of damaging the rack if I bang on it to hard. I am thinking that I will have to cut it off and start over.
