Results 1 to 3 of 3
Thread: coupe roof wind noise
    Jul 2014
    Strathroy, Ontario Canada
    So I had the newly converted 818S to an 818C out on the highyway 60-70mph and noticed the roof has a lot of wind noise over the top more through the roof scoop and the side PW flex in and out and have a lot of noise as well.
    Any one else notice this and did anyone do anything to try and correct any of this, better seal for the glass to get it to seal?
    Sep 2015
    Hamersville, Ohio
    I don't think those windows will ever stay sealed since there are no upper window frames. Are you sure the noise is coming from the top and not around your doors and front firewall/dash area? Did you use any sound deadened on your interior panels?
    Senior Member Presto51's Avatar
    Catonsville, Maryland
    This is what forum member Rumrunner did on his GTM 327. It worked really well
    https://www.ffcars.com/forums/42-fac...gtm-327-a.html
    Ron
