Results 1 to 15 of 15
Thread: Must haves from Forte
    Jun 2017
    Norway
    I am on vacation in Florida at the moment, and while I haven't received an answer to my build-application in Norway yet, I thought I'd start buying some parts to save on shipping and taxes. I am putting an order in with Forte to snag one of those CNC reservoirs before they are gone, and also a set of seat heaters. My question is what other " must haves" should I consider buying from him while I am at it?
    Jun 2017
    Norway
    Oh, and I forgot: planning on a mild 302, TKO, IRS, 17" wheels.
    Mar 2018
    Chesapeake VA
    Hydraulic Clutch?
    Depending on your build plans, you might consider his mid-shift kit for the transmission. It places the shift lever closer to thee dash, and as a result, allows a more upright shift lever.
    Mike also has a very nice mechanical throttle linkage kit. This allows a mechanical link between your accelerator pedal and the throttle, eliminating the cable connection, and providing better throttle response.
    He also sells a nice transmission spacer kit to help correct pinion angle.
    I am sure others have some ideas as well!
    Good luck!
    Cobra Doc
    Oct 2017
    Newton, MA
    He sells the rear spindles/hubs and differential at a good price. A few hundred less than directly from FF. His customer service is also just top notch, so I'd buy from him even it cost me more.
    Jun 2017
    Norway
    Quote Originally Posted by gkp200 View Post
    Hydraulic Clutch?
    Planning on that, but not sure wether I'll use a slave cylinder on the clutch fork or one that goes directly over the input shaft, not researched this yet. May buy the whole setup with blueprint engine and transmission in Norway
    Jun 2017
    Norway
    Good luck!
    Yep, was looking at those. So you feel the mechanical throttle linkage is a big improvement over the cable?
    Is there always a need for spacers for the pinion angle?
    Jun 2017
    Norway
    Quote Originally Posted by rsw81 View Post
    I have seen that one as well. It won't fit in my suitcase, so i will look into it when I order the kit. Probably will get it from Mike if I buy the engine and transmission from him as well.
    Dec 2013
    Sandia Park, NM
    Quote Originally Posted by Oystein View Post
    Mechanical throttle linkage is a big improvement.
    Didn't use transmission spacers so no feedback on second question.
    FFR #8305; IRS, 347; T5 Trans; EFI, 3.27 Rear; 17x9" Front; 17x10.5" Rear
    Paint - Ford Magnetic Metallic Gray (J7) with Black Stripes; Painted by "da Bat"
    Complete Kit Delivered 05/15/2014; Titled and Registered 4/14/2017 as a 1965!!
    Jun 2017
    Norway
    Quote Originally Posted by swwebb View Post
    Thank you. Looks like the linkage is a must then, will add it to my list.
    Mar 2018
    Chesapeake VA
    Mike sells engines and transmissions. He shipped mine with engine and trans already connected and hydraulic slave cylinder mounted and it was less that other engine builders.
    Grand Rapids, MI
    If your going with a carburetor or a carburetor style EFI his mechanical throttle linkage is great.
    Jun 2017
    Norway
    So I'm out of luck regarding the triple CNC reservoir, out of stock permanently apparently.
    Senior Member D02G's Avatar
    Mar 2019
    CT
    I searched the internet and couldn’t find any....
    Jun 2017
    Norway
    Talked to Mike, think he said he sold the last one three weeks ago, oh well.... He had a different set of reservoirs that I have ordered. Actually think they look more business/ racy, and not so bling, so they may suit my vision better. Should be here in a couple of days. Kinda backwards to start with the extra parts I know, but I am here in Florida now, so gotta take advantage of the empty space in my suitcase. Haven ordered the kit yet, but hopefully I'll get my Mustang sold so i can take advantage of the spring sale...
