Results 1 to 7 of 7
Thread: Harness Bar instructions
    Aug 2017
    Hello,
    I'm building a C with 5 point harnesses. I bought the FFR Harness Bar kit but can't find any instructions. I also can't find any decent pictures to sort out how to use the spacers.
    Can anybody point me in the right direction?
    Tybee Island, GA
    Videos are at: YouTube Videos
    Sep 2015
    Hamersville, Ohio
    The harness bar should mount on the cockpit side of the rear bulkhead. Pulling the belts tight should not compress your spine, so height of bar is important.
    Jun 2017
    They are posted on the parts page...Not much to them
    http://www.factoryfiveparts.com/cont...-bar-mount.pdf
    Senior Member DSR-3's Avatar
    San Jose, CA
    I don't think that's the designed location. The picture above is from FFR. Also, mounted on the front of the roll-bar would reduce seat clearance, and leave little/no room for the 3-bar slide on the harness. I recall that I may have needed to add a washer with the spacers to clear the roll-bar with the harness bar, and could not fit jam-nuts either (useless). Belt height/angle is important, but not really adjustable at the bar. Follow your belt mfg. installation instructions. Mine specified 0deg (horizontal) to -20deg shoulder belt angle. I see now that you're building a "C" so I may be totally off for that model!
    818S #332, EZ30R H6, California licensed 01/2019
    Aug 2017
    Thank you. I couldn't find that pdf, and it's exactly what I was looking for.
    Sgt.Gator's Avatar
    Bend, Oregon
    In the pdf the bar is mounted on the cockpit side, in the image linked above it's on the engine side. The engine side looks much safer to me. And every harness maker and racing regulation I've seen requires the belts to be even horizontal or down no more than 45 degrees from your shoulders.(Sparco says 45 degrees ; Schroth says 20) Schroth has the clearest instructions I've seen yet, here: https://www.schroth.com/en/segments/...-qg_online.pdf
    Owner: Colonel Red Racing
    818R ICSCC SPM
