Likes Likes:  5
Results 1 to 15 of 15
Thread: Spencer build in the UK
    Oct 2018
    Finally got my kit delivered today from the USA via Holland
    Can’t wait to start the build
    Boxes everywhere
  2. Likes wrp liked this post
    Senior Member JOP33's Avatar
    Haslet, Texas
    Congratulations, let the fun begin!
    May 2018
    Pinckney, MI
    Welcome to the party!
    - Peterh226 #1134
    Dreamer j33ptj's Avatar
    Wassenaar, The Netherlands
    Where are you located in the UK? Would love to drop in someday if it is not to cheecky to ask!!?
    Welcome to the fray
    Senior Member Barrel's Avatar
    Aug 2011
    Mornington, Victoria, Australia
    Congratulations. I am looking forward to a RHD build thread. Although we have a number of RHD '33 Hot Rods being built here in Australia I don't see much about them on this forum.
    Oct 2018
    Quote Originally Posted by j33ptj View Post
    Sorry for the delay
    I’m in Essex /M25 J31
    Spence
  9. Likes j33ptj liked this post
  10. #8
    Oct 2018
    Managed to get a few days in the workshop on the build
    Front suspension is all done, front brakes, rear axle and 3 link all done
    Brake lines front and back, pedal Box, wiring loom run, firewall, steering all done
    Need to source a rear brake set up as didn’t know there wasn’t one in the kit
    Engine and box in next ( got New Ford Performance Coyote engine )
  11. Likes wrp liked this post
  12. #9
    Oct 2018
    Couple of quick questions whilst getting the engine ready
    Notice my fuel tank has 6 threaded holes for the fuel gauge and pick up but I’ve been supplied a internal tank fuel
    Pump and plastic high pressure lines that don’t fit the tank hole or have anyway of fixing or sealing it
    Also a massive expansion tank for the coolant is this used as looks horrible
    I’ll
    Upload photos later
  13. #10
    Oct 2018
    Fuel Bits
    Tank with the fuel pick and other bits
    Wrong tank or wrong pump or me being stupid and missing something
  14. Likes wrp liked this post
  15. #11
    Oct 2018
    Also i have a ford alternator in a box but reading the install instructions, i need a Honda one ..??
  16. #12
    Simi Valley, CA
    Quote Originally Posted by Grusks View Post
    Yes, you need to buy the correct model year Honda alternator. The stock Ford alternator won't fit in the Hot Rod chassis and you have to cut off one of the alternator mounting bosses to fit the Coyote into the chassis. It's a tight squeeze, but it all works as shown in the build manual.
  17. #13
    May 2016
    North of sacramento Ca.
    I am using the ford alternator, wanted more power, To get the no clutch pulley ask for the auto trany pulley, Run as one wire alternator, do not hook up the wires from the PCM. Do not ask, it locked up and no belt on the way to CHP. Works good as one wire.
  18. #14
    Oct 2018
    Cheers guys
  19. Likes wrp liked this post
  20. #15
    How is the progress going??
