Thanks Thanks:  2
Thread: Sane banjo bolt torque specs?
    Senior Member Alphamacaroon's Avatar
    Jan 2019
    Richland, WA
    Does anyone else think that the banjo bolt torque specs are ridiculously high for the complete kit stock brakes? I was afraid I was going to strip the front brake calipers while doing it and I completely buggered a crush washer (not the way it's supposed to deform).
    Anyone else have a sane torque spec they use? Or does 29 lb/ft seem reasonable? I know 29 lb/ft is pretty low all considered, but it does not feel right for this.
    Senior Member SSNK4US's Avatar
    Bakersfield, CA
    I’ve been working on “stuff” for a little over 40 years, and I’m not saying it’s right but I’ve never used an actual torque wrench for banjo fittings on brakes, or power steering either for that matter. Just a wrench and my hand saying “yep that’s good” lol. Never had a leak. But I have seen on here that a few guys have broken banjo fittings off with a torque wrench.
    Just my 2˘ FWIW...
    Be careful....
    Kurt
    Build thread
    Senior Member Fixit's Avatar
    Aug 2017
    Minneapolis 'Burbs
    Same situation, turning wrenches for 40+... A light smear of fluid from your fingers on the parts, get it pointed in the direction you want, and then snug it down with an extra "tweak". You're dealing with a bolt that's 90% hollow, with a thin wall thickness.
    FFR and their suppliers have to publish torque values for fasteners (read that "Lawyer"). The engineering types will argue, but IMO it doesn't supersede common mechanical horse-sense.
    John D. - Minneapolis 'Burbs
  4. Thanks SSNK4US thanked for this post
    Likes SSNK4US liked this post
    Senior Member Mike N's Avatar
    Mooresville NC
    Use new copper washers. Copper work hardens so each time you compress the washer it is going to conform less and the risk of leaks increases. With new washers you should be able to seat the bolt and go something like a quarter turn to compress the washer and get a good seal.
    Mike............
    Sep 2015
    Hamersville, Ohio
    Quote Originally Posted by Mike N View Post
    If new crush washers aren't available, you can anneal the copper ones with a burns torch. Heat up until orange & allow to cool slowly. It works.
  7. Thanks Mike N thanked for this post
  8. #6
    Bakersfield, CA
    Yep he’s right. Omg seeing the word anneal instantly took me back the 8th grade metal shop! I learned and retained so much actual useful stuff from shop classes. I still have a tray on our kitchen counter from an 8th grade project. Talk about work hardening lol If you didn’t anneal it after beating it to death with a ball peen hammer to get the finish it would have just broken when trying to bend it. Ahhh the practical things you Lear’s as a kid...
    Build thread
  9. #7
    Jan 2019
    Richland, WA
    Thanks all. I had already ordered some copper crush washers to replace the one I buggered and so I'll be going with that all around. And thanks for the confidence to go by feel— I never considered that it was for CYA/legal purposes and just assumed they knew best.
  10. #8
    May 2019
    Yeah, I've never seen anyone use a torque wrench on anything like that, just not that critical.
