Going with airbox on driver's side, looking for an expansion tank (MyRaceShop kit) location on the passenger side. I'm not running any tank up front. How does this location look? My heater core will be behind the passenger seat in the cockpit. Will triangulate square tube off the square tubing behind the firewall to mount it. The only interference I see is that I'll have to unbolt the coolant tank in the rare event I need to pull the PCM. I like that this puts things on the same side as the water pump. I can remove the cap in its current location, or I could space it forward some. I think it's plenty high?
