Results 1 to 9 of 9
Thread: E-brake handle won't thread
    Jan 2019
    Any one else out there had an issue threading the E-brake handle (the chrome piece) onto the E-brake fixture? I can get it till it has about three threads left. After that, anything I can think of is going to really mess up the the chrome.
    Does it go all the way to till the threads are hidden?
    Thanks in advance!
    Jan 2019
    BTW - I did put some WD40 on there as suggested by the manual...
    Put it all together. If you can operate the button properly it will be OK as is.
    Jan 2019
    Thanks - I did try that but since the handle isn't threaded fully the button ends up inside the handle.
    I guess I'm wondering if anyone has had to grip the chrome, have they used anything unconventional besides rubber (I'm using an old bushing) or leather (a leather glove), both in a vise.
    I had a tight one once. I cleaned up the threads on the metal with my wire wheel. Then it went on say.
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    Quote Originally Posted by welske View Post
    Not specific to this problem, but if you have a vice and need to grip stuff that you don't want to mark up, I highly recommend a set of jaw covers. Something like these. I actually have a set of each of these, and they come in handy nearly every single day:
    https://www.amazon.com/Yost-MU360-Un...s%2C192&sr=8-3
    https://www.amazon.com/Yost-UP360-Un...s%2C192&sr=8-4
    Kirkland, WA
    Lots of people had trouble with these threads. They need to be cleaned up and lightly lubricated - took mine from a 'no go' to 'nice and easy'.
    BTW that handle (and button) is polished aluminum. Not chrome. It will scratch/mar/dent pretty easily. So don't manhandle it. I wouldn't put it in a vise. You should be able to get both sets of threads cleaned up for it to assemble. The ones I've done were a little stubborn at first as well.
    If you have a tap and die set, you could just clean the threads up pretty quick, especially of its aluminum..
