No personal experience. But I've seen several builds where the Mustang MT82 trans was used. Early ones didn't have a great reputation in Mustang circles. But maybe by 2015 they're sorted out. Yes the shifter location is a problem. Aside from fabricating your own, I've seen this solution discussed. https://www.formacars.com/blogposts/...ture-highlight. But I have no experience with it. Just passing on the info. You'll also have to deal with the driveshaft, because it's different than a TKO and what Factory Five offers. The Mustang has a 2-piece driveshaft with different adapters. Another consideration might be the ratios. I see the 2015 MT-82 has a 3.657 1st gear. Not sure how useful or practical that would be. 2nd through 6th are somewhat similar to a TKO 1st through 5th. I suspect the mounting frame and locations might be different too. But don't know any particulars.
General comment: Just keep in mind that you're describing a non-standard configuration that isn't supported by Factory Five. So you're pretty much on your own. If your experience level is sufficient, should be manageable. If you're more toward the beginner side (no offense, many on here are) it could get challenging. Just saying.
Build Thread and
Video.
Build Thread and
Video
Build Thread. Sold 11/9/2023.
