Results 1 to 5 of 5
Thread: Dielectric grease on connectors?
    Senior Member beeman's Avatar
    Indiana
    I have seen varying recommendations on this.
    Some say don't dare get it on the male/female pins of a connector since it is an insulator. Others say coat everything with it, then connect the connector.
    I did apply it liberally to the connectors on my injectors...do I need to unplug them and clean it all off?
    GTM #304 LPE 525hp LS3
    You're probably ok.
    All greases are lousy conductors, but dielectric grease is specifically designed to keep the contact surfaces from oxidizing or corroding (and therefore becoming a bad connection).
    Plenty of additional detail here: https://www.w8ji.com/dielectric_grea...ive_grease.htm
    Jul 2014
    I only use dielectric grease on my boat, but it will not hurt anything. I wouldn't bother taking them apart and cleaning.
    Vermilion,OH
    I use it on all connectors, particularly on the bullet connectors on my British cars. Haven't had a problem in 20 years.
    I wouldn't worry about cleaning it off...or putting any on in most cases. It's not going to hurt anything, but it is kind of a mess if you would ever have to work on the connectors you apply it to. All of the engine bay connectors should already be sealed/weather tight, so no need for it.
    Shane Vacek
    www.vraptorspeedworks.com
