Results 1 to 15 of 15
Thread: Remote brake / clutch reserviors
    Jax Beach, FL
    Now that CNC is out of business, what are you guys using these days?
    I have a double and am going to a hydraulic clutch, so I need a triple. I can't find anyone that has one in stock.
    Here are a couple that I have seen.
    https://www.summitracing.com/parts/o...saAo0UEALw_wcB
    Jamar - looks a bit like CNC. I don't really like the modern style logo that much. JAM-JRR-1300.jpg
    http://www.jamarparts.com/jamar-remo...nd-clutch.html
    Any other ideas? Or opinions on these?
    I might look for a place to add a different single reservoir. (And I can't change my misspelling in the title - OOPS!)
    Jun 2018
    North Vancouver, BC, Canada
    There's Kugel Komponents 5553 triple reservoir. I have one I will sell, bought it hoping to use it but didn't in the end. They are $180 US plus shipping, make me an offer if interested.
    Gen 1 '33 Hot Rod #1104
    Grand Rapids, MI
    I've used the Tilton 3-chamber and will use it in this build as well. It's plastic, rather utilitarian, certainly not flashy.
    Jim
    Apr 2019
    NC
    Not too pricey for a triple, just not much capacity. https://www.scottshotrods.com/remote-reservoirs/
    Quote Originally Posted by Jim1855 View Post
    Jim
    Ditto On The Tilton 3-Chamber
    Three separate reservoir levels, one 9.8 oz., one 6.3 oz. and one 4.0 oz. capacities.
    Front brakes on the largest, rear on the next and clutch on the smallest.
    https://www.summitracing.com/parts/til-72-576
    Alliston, Ontario, Canada
    How about the vintage Girlings?
    PaulProe's Avatar
    Manchester, MO
    Acton Custom
    (Click above to go to site)
    Jax Beach, FL
    Quote Originally Posted by PaulProe View Post
    Acton Custom
    You guys really want to spend my money. I do like the look, but $330 for 3 PVC glue cans?
  9. Likes WIS89 liked this post
  10. #9
    Jax Beach, FL
    I ended up going with the Girling style reservoirs. I really like the classic look. Moss Motors has them, made by Classic Gold, which makes quality products. If you need better wiper arms, I recommend Classic Gold.
    I got three of them and three brackets for around $230.00. They are on sale right now. These have the decal on them. They also have a diaphragm in the cap to keep air out and fluid in. Apparently the fitting is AN compatible.
    Thanks for the help.
  11. #10
    Jax Beach, FL
    I know that this is old, but I wanted to do an update. I HATED the Girling reservoirs. The decals (not stickers) are so fragile, that you cannot even handle the reservoir without damaging them. Then one of the caps galled while test fitting. It was not cross threaded. Hey, they are just like the originals.
    I got the mocked up, on a nice bracket, removed them, replaced a damaged decal, and returned them.
    I ended up finding a triple CNC.
  12. #11
    Jun 2017
    Norway
    Jim
    I have the low profile 3 chamber Tilton. Any chance you have a pic? Would love to see the mounting position.
  13. #12
    Grand Rapids, MI
    Oystein,
    My original install was on Superformance cars. Mounted center as high as possible on the firewall.
    Not sure how I'll mount it on the Challenge car but I'm planning on the same central location. I am concerned with gravity flow into the master cylinders.
    PM if you wish.
    Jim
  14. #13
    Folsom, CA
    Todd
  15. #14
    I made my own to look like the ones sold by Nick Acton for less than $100
    I later moved them to the front of the footbox as per originals
  16. #15
    Nov 2016
    "The i.e." SoCal
    Mike Forte came out with his own very similar to the CNC ones. Give Mike a call.
