Help with Hardware
Hi
I am just about ready to mount the body for the final time and I would like to know where all this hardware gets used. Not a picture in the manual of any mounting hardware usage, except lower door sill revits and two rear body mounting points. There are at least 35 bolts, nut, and washers in one package and about 15 rubber grommets in two sizes with screws in an other. See the pictures.
I’m at a lost as to were all this hardware is used and any help would be appreciated.
I know to rivet the door sills, the fire wall (mix of rivets and screws/rivnuts), and the two large bolts that go through the under fender area. These mounting points would not use grommets and only use a few bolts. This is all the info I gathered from the manual.
