Results 1 to 2 of 2
Thread: Extra Clearance Hood & Prop Rod Location
    Senior Member JOP33's Avatar
    Haslet, Texas
    Reaching out to those of you that opted for the Extra Clearance Hood...Any suggestions on where to mount the prop rod? The manual shows the supports that run down the middle of the hood , however these have been eliminated on the ECH. Would like some feedback regarding this as well as pics if available.
    Thanks ahead of time!
    Aug 2013
    Gatineau, Quebec, canada
    I had the same issue, the hood is different so you can't install it in the same way as the standard hood. I spoke with Tony and he suggested to mount it on the firewall like they done on the FFR Flame 33 Hot Rod. I have a pic in my build thread which shows it, #231 is the thread.
    https://thefactoryfiveforum.com/show...3-Hot-Rod-1028
    once the car is painted and the body is back on I will be installing it in the same manner however I will be painting it the same Burnt Copper as the firewall so it blends in a bit better.
    Andreas
  3. Thanks JOP33 thanked for this post
