Results 1 to 5 of 5
Thread: Airflow around footbox into cab - how to seal?
    Dec 2018
    Short of removing the body, I'm just wondering what others have done to seal off the the voids between the aluminum panels and the fiberglass body to prevent heat from getting into the cabin from the air flowing past the headers/sidepipes and into the cabin?
    I am not talking about the heat "through" the footbox panels. I'm talking about the air flow around the aluminum footbox area between the side of the car body.
    Depending on the spot it varies between almost 2" to a small gap and without removing the body it seems like it would be difficult to seal the gap.
    Driving at about 60 mph there is a tremendous amount of very warm air coming into the cabin which if I put my hand between the frame and fiberglass I can feel is coming in.
    That was fine during the winter driving when a bit of extra heat didn't matter but now that we're getting to the hot summer months it's making it overly warm in the cab.
    Just wondering if anyone else has tackled this issue on an already finished car and if so, how you solved it?
    The kit includes expanding foam and the instruction manual shows installing right before the body is installed for the last time. But common that the step is missed or another method is used instead. Some options in these threads, and can be done on a completed car:
    https://thefactoryfiveforum.com/show...-past-the-dash
    https://www.ffcars.com/forums/17-fac...-firewall.html
    Dec 2018
    Thanks Edward. That's exactly what I was looking for. Found some good ideas.
    Senior Member skidd's Avatar
    Jan 2016
    SA-TX
    I wasn't convinced the kit foam would work, so I removed the front elephant ears for easy access, and with a stick, shoved prieces of pretty stiff foam into all the cracks. Works perfect, not any hot air coming in.
    Pool noodles are the bomb, IMO.
