Results 1 to 6 of 6
Thread: Pillow Block Won’t Slide on Steering Shaft
    Central Lake, MI
    Working on installing my Russ Thompson steering system today and noticed the FFR supplied pillow block would only slide onto the steering shaft about 5-6 inches. The end section of the steering shaft appears to have a taper. Anyone else experience this? Should I see about getting a replacement shaft or pillow block from FFR?
    MKIV #9542 Complete Kit, Coyote, IRS - Delivered - 2/19/19, First start - 9/8/19, Go Cart - 9/14/19
    1965 Mustang Convertible 4v 289
    Build Thread HERE
    O'Fallon, MO
    Emery cloth or sandpaper.
    Apr 2018
    Colgate, WI
    Put mine together 2 weeks ago, no problems with the shaft.
    Mk4, IRS, (Forte: 427 with EFI, T-56 MAG, hydraulic clutch, mechanical linkage, reverse lockout control module) (Breeze: Front and Rear Double adjustable QA1's, Cockpit cubby, LED Lights, Fan Shroud, Fan Lower Support, Oil Cooler Coil, power steering hose kit) (Russ: Drop Trunk, Turn Signal)
    Mar 2013
    Medway, MA
    Probably a scratch or burr or ding in the OD. A quick dressing with a file followed by some polishing with emery cloth will help.
    Also check the ID/OD with calipers.
    Heart of Dixie, Alabama
    I dressed mine with a belt sander, good to go.
    Central Lake, MI
    After 15 min of sanding it slide on freely! Thanks for the advice.
    Build Thread HERE
