Results 1 to 3 of 3
Thread: 4L70E transmission shifter
    Jan 2019
    Anyone have any info on the correct Lokar shifter for a 4L70E mated to aLS3 in a 33 Hot Rod? Iíve read they are hard to fit?
    Nederland, Texas
    Quote Originally Posted by kentsplain View Post
    33 Hot Rod Stage 1 delivered on 4/27/2017, Stage 2 delivered on 9/21/2018
    LS3 376/480, 4L70E, Electric PS, Classic Auto Air, Lokar electronic sport shifter,
    Ford 8.8 w 3.73 w 4 link, Billet Specialty Legend Series MAG wheels and Mickey Thompson
    Sportsman S/R 26x8x18 front and 29x18x20 rear tires
    Placitas, NM
    I used the same shifter too. If you are going to build a console above the tranny cover and mount your shifter like I did consider ordering it with the 6" shift rod. The standard rod is only 4", however that is measured from the bottom of the nut at the base to the top of the mushroom ball.
    See post 148 for how I mounted the shifter.
    https://thefactoryfiveforum.com/show...-s-Build/page4
    4" and 6" shift rod, 1st two pics in post 260.
    https://thefactoryfiveforum.com/show...-s-Build/page7
    '33 Hotrod, #1047, delivered on 2/27/18, go cart on 9/24/18.
    LS3 w/4L65e, Lokar shifter, Electric PS, Vintage AC/Heat/Def, 8.8" 3.55
    TorqThrust II Wheels w/Toyo Proxy T1 Sport Tires, F 245/45ZR17 R 295/35ZR18
