Results 1 to 4 of 4
Thread: Thread Sealant
    Central Lake, MI
    Thread Sealant
    When installing my CNC Triple Reservoirs I used Permatex High Temp thread sealant on the NPT to barb connections that threaded into the bottom of the reservoirs. After a week plus the sealant was still just as soft as the day I applied it. Should the sealant harden? Thinking it should, I removed the connectors, cleaned them and tried Loctite 547 instead. Same result, didn’t harden. Please let me know what to expect. I’ll be installing the NPT connector in the clutch master cylinder soon and wanted to make sure it I sealed appropriately as well.
    MKIV #9542 Complete Kit, Coyote, IRS - Delivered - 2/19/19, First start - 9/8/19, Go Cart - 9/14/19
    1965 Mustang Convertible 4v 289
    Build Thread HERE
    bobl's Avatar
    Spicewood, Texas
    No it doesn't harden, but seals very well.
    O'Fallon, MO
    If it hardens, it will shrink, If it shrinks it will leak. Thread sealant needs to stay soft and pliable to do the job of sealing against leaks.
    Seasoned Citizen NAZ's Avatar
    What Rich said...
