Thanks Thanks:  2
Results 1 to 9 of 9
Thread: Gen 3 Coupe Hood Underside Treatment
    Atlanta, GA
    I am curious if Gen 3 folks have any good ideas on how to treat the underside of the hood. Previous generation hoods appear to be one piece and smooth making it easy and clean to just coat with bedliner. The Gen 3 underside is comprised of several different pieces/panels and is not smooth at all. The portions of my hood underside that are laid-up fiberglass are already painted with something black. The smooth panels in the hood are black as well. So, it is all black, but doesn't look clean at all. In addition, there is extra adhesive clumps and gaps in some of the panels that don't affect the function, but look sloppy. I have a feeling I don't have much choice here to make it look clean. I hesitate to say that I want show car quality, but if one wanted show car quality, what could one do?
    Gen 3 Coupe, Gen 2 Coyote, Wilwoods, IRS, Power Steering, AC JDAVIS500 Build Thread
  2. Likes GThompson liked this post
    Gorham, ME
    This is much cleaner then the previous generations where, however if you want a really smooth finish talk to your painter about it. They can sand and fill the imperfections just like any other bodywork.
    HTH,
    The hills of TN
    Whoa man that is a lot better than my late production black body coupe was. I used a product called Grizzly Grip on the bottom of mine.
    If in doubt......flat out-Colin McRae
    Coupe #485
    Yea, the Gen 3 Coupe has a inner shell that wasn't on previous versions. Still undecided how I'm going to treat mine...
    Jan 2019
    Richland, WA
    I've been considering using a reflective hood-liner— something like this http://www.dynamat.com/automotive-an...ion/hoodliner/. Might not be the look you're going after, but it seems like a good way to apply a relatively uniform look to a large surface without a lot prep-work. Plus it provides some heat protection for the paint and decals in the hood area. Thoughts?
    Atlanta, GA
    Not a bad idea. If a large enough piece is available, fastener posts could be glued to fiberglass, and a fastener button of sorts on top to keep it in position. For me, it would be all about the finished look. Think I would prefer black. The bulk hood insulation is a little pillowy for my taste. OEM stuff is thinner, but seems to be precut and molded per model. Maybe there are more options.
    https://www.summitracing.com/parts/o...0142/overview/
    Atlanta, GA
    This may be a good option. It says peel and stick. I wonder how well the adhesive would perform on the fiberglass.
    https://www.summitracing.com/parts/dei-050129
    Here is a smooth ABS possibility with custom embossed emblem.
    https://www.quietride.com/acoustihood.html
  9. #8
    Jan 2019
    Richland, WA
    Crazy thought— what about landscaping fabric? It's black, it's not pillowy, it's cheap, you can get it in big sections, and it's made of polypropylene (which I think would withstand the heat??). You could probably attach it with contact adhesive. It reminds me a lot of the stuff they use in OEM hood liners already.
    Here's a picture of some stuff you can buy at home depot. Doesn't look half bad IMHO.
  10. Thanks jdavis500 thanked for this post
  11. #9
    I used UPOL Raptor undercoating on the underside of the nose and also under the rear fender-wells.
    I wanted something 'catalyzed' that set up hard/firm and this stuff does.
    I did not want to make a mess spraying it so I applied it with disposable 'chip-brushes', just dabbing it on to get it sort of random. I did 2 coats.
    I did fill the major gaps between panels with short-strand-filler first-just used my gloved finger to smooth it in there. No sanding.
    Attached is a pic during the application and a few after a couple thousand miles (some driving in light rain and I've never cleaned it).
    Works for me.
    Dave #17
  12. Thanks jdavis500 thanked for this post
