Thread: Outside to outside length of the sway bar Please!
    Jan 2019
    My sway bar is too long it doesn’t fit inside if the spindle bracket.
    Thanks ahead of time
    Please post a picture of your bar.
    Jan 2019
    Quote Originally Posted by walt555 View Post
    Bowling Green, KY
    A few others have posted that aftermarket rear (818 front) bars won't fit. What I recall is they are about an 1 inch + too wide.
    Jan 2019
    yup!
    Bowling Green, KY
    Building a bar isn't that tough if you want to take it on.
    Here is the rate calculator I used when building mine. http://www.gtsparkplugs.com/Sway-Bar-Calculator.html
    I was able to use the FFR links (Cut down) and some of the hardware. The rest I got from Merlin Racing https://www.merlinmotorsport.co.uk/s...nts-and-spares
    Beware the sway bar mounts on the chassis are not the same height. Not a big deal the pads are big enough to raise the low side to level the bar.
