Sorry for the cross-post. I put this in my build thread but I'm pretty stumped so I thought I'd post it as a separate question. I've been working on the Wilwood pedal box today, and I've run into a bit of a surprise that I'd love some input on. The clutch pedal appears to be hitting the 3/4" tube and not able to extend fully to the back of the footbox. I'd read about this issue in many older build threads but was under the impression that this issue had been resolved on the newer frames, so I'm a bit surprised to run into this. I don't see how I can adjust anything (or have installed anything incorrectly to have caused this), so I'm a bit confused at the moment. The clutch pedal, when fully depressed to the point that it's hitting the 3/4" frame member, is still ~9/16" away from the footbox back. Is that "close enough" or do I need to do something here to resolve this issue?
The footbox sheetmetal is tight to the thick plate behind it:
Both support brackets are in position properly, per the instructions:
Here you can see where the pedal is hitting the 3/4" tube:
Here you can see how far the pedal is from the footbox wall:
