Results 1 to 5 of 5
Thread: wiper fuse?
    Jul 2014
    Strathroy, Ontario Canada
    wiper fuse?
    I have a stand alone wiring I made for my PW motors on my Coupe, I am trying to figure out if I have an intermitent short somewhere or the wrong fuse, what is everyone using for a fuse on the factory five PW motors?
    It will be fine for a week or so, go for a drive and when returning I go to put the window up and the fuse is popped. I cant tell if it pops when I go to use it or if it popped while driving. thinking its while I am driving.
    did you put the momentary breaker in that when it reaches full up or down trips
    I have one if you need it
    i m sorry I thought you were talking about PW
    Placitas, NM
    It's probably the same motor that is used in the hotrod. Mine draws 10 amps.
    What size fuse are you using for each window?
