Likes Likes:  3
Results 1 to 5 of 5
Thread: Rear exhaust routing with IRS
    Jun 2018
    North Vancouver, BC, Canada
    Did a search to find a thread dealing with this but didn't come up with anything. Seems likely someone has dealt with this already but darned if I can find it.
    The instructions on the FFR web site for installing and routing the rear exhaust are outdated. The manual has a section for the rear exhaust option which seems more up to date but following it has its problems.
    The manual suggests routing it just above the center section like this
    However, clearance to accomplish this is next to none.
    In addition, the instructions suggest cutting two holes off the top of the hanger strap but the strap barely reaches the cross bar as is never mind after cutting it. Seems like something is just wrong.
    I've noticed at least 1 other person moving the loop over the rear end outboard like this:
    Clearly I'd have to redo the brake lines (not happy about that) but this routing sure gives much better clearances:
    Is that what everyone is doing now or am I missing something?
    Thanks for the help
    Gen 1 '33 Hot Rod #1104
    Placitas, NM
    I did it like your first pic shows. Clearance was OK and I had to cut my hanger straps.
  3. Likes FF33rod liked this post
    Jun 2018
    Hmmmm. When you say OK, was it 1/4 or more? I think you can see from pic #2 I'm looking at 1/16
    Placitas, NM
    A 1/4" or better. Clearance will depend on everything from the engine all the way back.
    We have different engines so the position of the engine exhaust manifold may be slightly different.
    Aug 2013
    Gatineau, Quebec, canada
    I routed it like your second pic as I could never get the right clearances. Now how a lot of play and also the tips line up with the lights which I like better for the look.
    20181201_140256.jpg 20180901_094635.jpg 20180901_094629.jpg 20180522_111638.jpg
    I used the extra hole where the shock connects for the mounting bracket as well.
    Andreas
  7. Likes FF33rod, 60's Kid liked this post
