Results 1 to 5 of 5
Thread: Manual Choke Conversion
    Senior Member jwebb's Avatar
    Longmeadow, MA
    Currently have a Quick Fuel 750 with a electric choke, doesn't work very well. Either the choke won't set or if it does it doesn't open completely after warming up Convert to a manual or continue to struggle getting the right setting?
    Seasoned Citizen NAZ's Avatar
    Never had one I couldn't adjust correctly -- don't give up. Make sure you have a large enough conductor to carry the load and that it is switched by the ignition "run" position (as opposed to the Start position). If you don't know Holley's procedure for adjusting then do yourself a favor and read the procedure. The choke won't "set" until you push the throttle down far enough that the spring tension will move the choke linkage to the high-speed idle position. And if it's not opening completely that is typically a simple adjustment.
    Most of the issues I've come across are related to improper installation and adjustment.
    I've had a QuickFuel 650 and 750. Both with electric choke and both worked perfectly. Agreed, don't give up. Check that you have a constant 12 volts as mentioned. Follow the instructions for adjustment, although I never had to touch mine. It should close and set with a stab of the accelerator when cold. The electric heating coil should have the choke plate fully open in about 10 minutes. Make sure both are happening. If they are, could be something else, e.g. basic carb adjustment including 4-corner idle circuits.
    I went manual. The electric choke shut off too soon no matter what. As you crank it to stay on longer that also makes it way too rich for a lot of the warmup period. I bought a generic push pull cable assy. Made a small bracket to hold the outer sleeve, and bent a loop into the end of the cable.
    CHOKE Manual by craig stuard, on Flickr
    I also swiss cheesed the choke plate so I could have it on to hold the increased idle speed longer. Looking down from the top I put a slight curve in the cable so it would stay on the pin. Once I got it finalized, I ground a small notch in the black cover for the cable to pass through and put it back in it's normal spot. Been this way for 6 years.
    This Might Help:
    https://youtu.be/daK-go2PMrk
    Or Maybe Not!
