Thanks Thanks:  19
Likes Likes:  394
Page 6 of 12 FirstFirst ... 45678 ... LastLast
Results 201 to 240 of 457
Thread: Seths 33- 1133. Famous guy donut post.
  1. #201
    It helped quite a bit. My drivers door is workable now.
    I’m a whole lot closer than I was a couple of days ago. At least they’re hanging now.
    33 Hot Rod #1133. LS/TKO600
    Titled 2-28-20
    MkI.IV 2643k
  2. #202
    Placitas, NM
    F5 had to send me a new drivers door too. I still needed washers to get the lower front to align with the body.
    The top of the door doesn't evenly align to the top side of the body when closed, will need to do some grinding and glass work to fix it.
    Seth, does the rear lower corner of your doors hit the body when they are closed? Both of mine do, not sure I can adjust for that.
  3. #203
    Not sure yet.... but it’s a challenge.
    Titled 2-28-20
    MkI.IV 2643k
  4. #204
    It’s funny how driving the car makes up for the irritation with the doors. Get pissed, do a couple laps. All better.
    Titled 2-28-20
    MkI.IV 2643k
  5. Likes WIS89 liked this post
  6. #205
    Fair warning to us newbies. Doors must be adjusted with the weight of the vehicle on the ground. Apparently adjusting them on the lift results in a non-adjusted door when you set the car down.
    Titled 2-28-20
    MkI.IV 2643k
  7. Thanks FF33rod, wrp thanked for this post
    Likes wrp liked this post
  8. #206
    Sep 2019
    I'm glad I'm not the only one having issues with the drivers side door, as unfortunate as that is. Mine broke at the latch after twisting it into shape with washers. FFR sent me a new one, but the replacement wasn't much better. I ended up making a few relief cuts near the latch and glassing it back together while clamped to the body. I didn't like the washer idea either, so I ended up pre-twisting the metal frame to pull the door straight.
    The adjustment concerns me as I started on the body first, did your gaps change with the weight on the ground?
  9. #207
    Kingsland, TX
    Quote Originally Posted by sethmark View Post
    That's a bit disconcerting... You would not expect this type of chassis to flex that much just setting it on the ground.
  10. #208
    I build dirt track race car chassis for a living. I wouldn’t say that the deflection was any worse than I anticipated. You should see a box tubing chassis from an OEM car without the body. They’re like limp noodles.
    Titled 2-28-20
    MkI.IV 2643k
  11. #209
    Kingwood Texas
    I could use your opinion on the chassis flex issue Seth (or anyone that wants to chime in)
    Now that I have the first coat of primer on my car my plan is to re-assemble the body then block sand it while also aligning the body-lines, gaps, etc. The thought would be that after I have all of the panels fitted, blocked, and gapped that I could effectively remove the body and paint it in pieces. I'm then planning to move on to the mechanical work and wouldn't re-install the body until I'm done with full powder coating and assembly of the chassis/mechanical part. Do you think that there is enough deflection potential within the chassis to cause issues with this plan?
    Just thinking out loud, a loaded chassis on a lift would deflect in the front because of engine and front suspension weight. I'm trying to envision how that correlates to what I'm doing, non-loaded chassis body alignment without the chassis sitting on the four suspension points. I wonder if it may be better for me to revise my plan to do another mock up after I've finished the chassis/mechanical before final paint.
    33 HotRod #1142
    Started 5-9-19
    Kingwood, Texas
  12. #210
    Jun 2018
    North Vancouver, BC, Canada
    Would suggest waiting to do the final paint until all the mechanicals are done. As you make progress through the mechanicals you are going to want to make sure that there is no interference with various parts of the body which means you are going to be working with different pieces of the body and it would be a drag if you were to scratch or have to modify an already painted part.
    JMO
    Gen 1 '33 Hot Rod #1104
  13. #211
    To be honest, I don’t know the answer to that question. Virtually all of the weight of the car is between the front and rear axles....I would expect the frame to show some deflection in the middle.....the 300 pound frame suddenly weighs 1500 pounds. I can’t tell you that the difference would be visible to the naked eye, but it was enough to make a door that opened and closed easily, sticky. It was easy to adjust out, but it had to be adjusted out.
    Considering where you are in the process, I would seriously consider building the chassis and then cutting door gaps. I do not have the depth of experience with a GEN two car to know for sure.
    Titled 2-28-20
    MkI.IV 2643k
  14. #212
    Simi Valley, CA
    Sorry for the thread hijack, but please answer a question from a bodywork novice: what gap are you shooting for at the door edge? Same gap around the trunk lid? Thanks, Keith
  15. #213
    Gatineau, Quebec, canada
    I started with close to a 1/4" gap and once primed and painted I ended up close to 3/16" which is a relatively tight gap based on feedback and some industry experts, so i was happy with that.
    Andreas
  16. #214
    I finally have made enough progress on the doors that they open and close.... And latch. The trick seems to be to hang the door loose and get it to latch. Once it latches, you can shim it into place and tighten it all down. My gauge cluster should arrive today and that will allow me to finish up most of the wiring.
    Titled 2-28-20
    MkI.IV 2643k
  17. Likes FF33rod, AJT '33 liked this post
  18. #215
    Trunk lid was simple enough. A little adjustment to get it sitting flush and I’m done with it.
    Titled 2-28-20
    MkI.IV 2643k
  19. Likes FF33rod liked this post
  20. #216
    Hand sanded the parting seams today. That sucks.
    Titled 2-28-20
    MkI.IV 2643k
  21. Likes FF33rod liked this post
  22. #217
    Titled 2-28-20
    MkI.IV 2643k
  23. Likes FF33rod liked this post
  24. #218
    Jun 2018
    Cool gauges, how deep is the main gauge? Wondering if you have to put it in the center or will be able to put it right in front of the driver.
  25. #219
    2.5" depth. They’re super shallow. And there’s no connection other than cat 5 on the gauge.
    Titled 2-28-20
    MkI.IV 2643k
  26. Thanks FF33rod thanked for this post
  27. #220
    My ocd is happy....
    Titled 2-28-20
    MkI.IV 2643k
  28. Likes FF33rod, Mrallsport32 liked this post
  29. #221
    Oh... and a little sneak.....
    Titled 2-28-20
    MkI.IV 2643k
  30. Likes FF33rod liked this post
  31. #222
    OBDII Hookup is key...
    Titled 2-28-20
    MkI.IV 2643k
  32. Likes FF33rod, JOP33, Mrallsport32 liked this post
  33. #223
    I’m happy. Got some ideas for pinstripe and paint too....
    Titled 2-28-20
    MkI.IV 2643k
  34. #224
    Titled 2-28-20
    MkI.IV 2643k
  35. Likes JOP33, FF33rod liked this post
  36. #225
    Details on the headlights. The park wire, which is tan from the chassis harness, is not utilized. The turn signal from the car powers both the daytime running light and the turn signal. They have to be paired going into the headlight. I’m not running DRL‘s.
    Outback, make sure to not wire in the brake light Wire. Simply wire only the ground, turn, and dim. Wiring in the brake light wire back feeds.
    Titled 2-28-20
    MkI.IV 2643k
  37. Likes FF33rod, HVACMAN liked this post
  38. #226
    Hey Seth - are those the lights that come with the kit? I like the integrated signals.
  39. #227
    Quote Originally Posted by sread View Post
    Yessir.
    Titled 2-28-20
    MkI.IV 2643k
  40. #228
    Village Mills, Texas
    I received the same lights with the Gen 1 and they were not in the manual. FFR sent me the digital Gen 2 manual and I elected to use the DRL's.
  41. #229
    Trunk latch is a pain. Doesn’t work well in any direction. I need to lengthen the striker pin and had to bend the hell out of the striker mount a good 10*.
    Windshield is another fiddly bit to fit....
    Titled 2-28-20
    MkI.IV 2643k
  42. Likes HVACMAN liked this post
  43. #230
    Jun 2018
    You're truckin' Seth!!! not sure how you find the time....
    One thought on the windshield, since we want a nice fit with the cowl/dash and that area is likely to need filler, sanding, etc to finish it properly, I was thinking of getting the mounting sorted initially but not doing any "fitting" until most of the body work is done. Thoughts?
  44. #231
    My existence is atypical.... my wife has already relocated for her job, I don’t need to be working much during our transition and my kid is gone from 7:30 in the morning till three. So right now I have time to mess with the car. A good bit of it is also wheelhouse stuff for me. The mechanicals were things that I was intimately familiar with. It’s just what I know how to do.... Probably best not to ask me to do surgery, try a case in front of a jury or sell something.
    I am not tightly fitting the windshield to the body. Just roughing it out close enough to be close enough. I intend on driving the car through most of 2020 before paint. With that said, I was not anticipating sucking up the fiberglass to the bottom of the windshield frame, but that’s clearly part of the fitting process. The windshield is not a lot of fun to work with. In fact, I found a fair amount of the car to be fiddley and less fun since the body went on.
    Titled 2-28-20
    MkI.IV 2643k
  45. Likes FF33rod, JOP33, duff33, HVACMAN liked this post
  46. #232
    Jul 2017
    It took me quite awhile to get the hard top to fit the body. Check out my posts on how much fiberglass work I had to do to get everything right
  47. Likes HVACMAN liked this post
  48. #233
    I think the kid and I have the basics in place. The mechanicals seem to be solid. I’ve got about 40 miles on the car around the test track. Car needs an alignment better than a tape measure.
    On to Body work and interior......
    Titled 2-28-20
    MkI.IV 2643k
  49. #234
    Couldn’t resist.
    Titled 2-28-20
    MkI.IV 2643k
  50. Likes FF33rod, HVACMAN liked this post
  51. #235
    This morning I got up really early and trailered the car to a private road in another country.
    Titled 2-28-20
    MkI.IV 2643k
  52. Thanks WIS89 thanked for this post
    Likes CVOBill, FF33rod, Mrallsport32, WIS89 liked this post
  53. #236
    Jun 2018
    LOL, must have been the same country I took mine to!
  54. #237
    Put this in the back of your head for electrical gremlins. If you powder coat the bracket that the alternator bolts to the motor with, make sure that you knock off the powder coat on the mounting bosses on both sides.
    Alternator and engine sides. Otherwise it just drains your electrical system and doesn’t charge.
    Titled 2-28-20
    MkI.IV 2643k
  55. Thanks Straversi thanked for this post
  56. #238
    might be.... they had gas....
    Titled 2-28-20
    MkI.IV 2643k
  57. Likes FF33rod liked this post
  58. #239
    I totally poisoned the well driving the car yesterday. I want to do it again so bad I can't see straight.
    Titled 2-28-20
    MkI.IV 2643k
  59. Likes FF33rod, WIS89 liked this post
  60. #240
    And that’s it folks. All forward progress stops until after the move. I feel pretty good about what the kid and I accomplished. Certainly if push came to shove I could drive the car to Virginia from here. That’s accomplishment in and of itself.
    The good news is that the registering process in Virginia and the replica laws are excellent. I should be able to get a plate on it after the first of the year and enjoy driving it while I finish the body and interior.
    On an unrelated note, my new shop is on the property of Virginia international raceway. I will be continuing to build late model mini dirt track chassis as well as offering DIY garage space and tools for privateer racers.
    I think after I get this car a little further along I’m going to do an 818 for daily driving.
    Titled 2-28-20
    MkI.IV 2643k
  61. Likes TxMike64, HVACMAN liked this post
