While I'm still patiently waiting for my painter (come on Jeff, this waiting is killing me) I have my car at a stage where I can get my title and registration so that I can drive it to the LCS and meet everyone and have some fun. Here is the process in Ohio.
A kit built vehicle is classified in Ohio as a self-assembled vehicle. Google "Ohio self-assembled vehicle title" to get the very minimal information that is out there. Basically the process is to gather all of your paperwork (ie receipts and sales invoices for the kit itself and all the major sub assemblies; engine, trans, clutch, bellhousing, rear axle or IRS parts, and your Manufacturers Certificate of Origin from FFR). Make sure you have VIN numbers for the donor vehicle of any donor parts; in my case only a rebuilt rear axle from MPS. Then mosey on down to a BMV license agency wait in line, pay $53 and get a receipt for a self-assembled vehicle inspection. Go online to the Ohio BMV website and schedule an inspection. You need the code on the receipt in order to do this. There are eight inspection sites in Ohio and you need to take the vehicle to the inspection site. Choose your site and schedule a time. The printout paper showing your scheduled visit states that you are granted permission to drive the vehicle to and from the inspection site on that date. I choose a site that was a 140mile roundtrip on I-77. That was my first time driving the car over 40 mph! I had my wife follow me with her car "just in case". But, the car ran great! It was fun but also a little nerve-racking and I was proud that it went smoothly. OK, back to the process. Bring your receipt and scheduling papers and your proof of insurance if you drive it there, otherwise if you get stopped you are in a bit of trouble.
Here is where things get a little vague. Nowhere could I find a list of what you need on the car to pass the safety part of the inspection. The inspection consists of three parts. First the officer takes all of your paperwork and enters what he needs into a computer record. Once all that is good they proceed to the safety inspection of the actual car itself. They check that you have DOT approved lighting: high and low beams, running lights, brake lights, turn signals, emergency 4-ways. They check your horn and TWO SPEED WIPERS! They look around and judge the quality of your build. But here is where they got me. Ohio requires BUMPERS on the front and rear of the vehicle. Quickjacks or just overriders are not sufficient according to the letter of the law. in my case the inspectors were not really up on dealing with self-assembled vehicles and knew the car didn't have sufficient bumpers, but they couldn't really tell me specifically what I needed to pass and actually quoted specs that I found out when I got back home were not accurate. So they failed me and I had to schedule another inspection for next Monday. I have a friend right here in town who built a Mk3 and a '65 Coupe and he never ran into this problem so it was never even mentioned when we discussed what to do for the inspection. Since then I found out the specific bumper requirements. in Ohio the bumpers must be at least 4.5" tall, solidly affixed to the frame of the vehicle (ie normal quickjack mounting bolts are OK), reach to within the tire track of the vehicle, be no lower than the bottom of the main frame rails, and the bottom of the bumper can be no higher than 22" off the ground.
What I am doing to pass my inspection is fabricating bumpers using 1/2" steel electrical conduit and some 1.25" x 0.125" steel flat stock. They are essentially old school "nerf bars" and will be fastened where the quickjacks normally go using the same hardware and spacers. They will be immediately removed after I pass the next inspection. Once I pass the safety inspection the inspector will issue me an Ohio VIN and will affix one of the metal tags to the 2" frame rail below the steering wheel next to where FFR stamps their serial number. They will give me a second VIN number to affix to one of the frame rails underneath in a less conspicuous place. At that point I can go to an Ohio title office with the tax bill that the inspectors generate based on my paperwork and the passed inspection certificate. Upon paying the tax they will give me a title with the Ohio VIN. Then I can go next door to the license bureau and purchase the plate.
Has anyone else run into this issue? I would be interested in hearing what was done to meet the requirements. The rear overriders and bumper bar that is available from ********** would probably meet requirements for the rear, but the front overriders and center loop bar would not be wide enough according to Ohio.
So, sorry for the long post but I hope it helps other builders here in Ohio keep up with the process as it atands in 2019. I will try to post some pictures when I get done fabricating my "nerf bars" and I will follow up with how it goes on 6/3 with the inspection. Hopefully I will pass and I will be the one with a gel-coat finish at the LCS.
John S.
#8866
Blueprint 306, T5z, 3-Link w/ '95 Mustang Cobra rear axle, Moser axles, 3.55:1 gear, CVF Racing front accessory drive with Saginaw PS, FFR heater/defroster, HotSeats seat heaters, FFR windshield wipers, Russ Thompson self-cancelling turn signals, FFR replica gauge set, 15" FFR Halibrand replica wheels
failed.pdf
